Finding the Domain of a Function
In summary, the restrictions for finding the domain of the expression \sqrt{(x^2 + 4)/(x^2 - 4)} are that the fraction cannot have zero as a denominator and the number under the square root cannot be negative. Therefore, to find the domain, you need to determine the values of x that will result in a zero denominator or a negative number under the square root.
megacat8921
How do you find the Domain of \sqrt{(x^2 + 4)/(x^2 - 4)} ?
Mathematics news on Phys.org
What restrictions are implied by a square root? What restrictions are implied by a fraction?
There cannot be a negative number under the square root and a fraction cannot have zero as a denominator. Knowing that, I still cannot figure out what steps to take to figure the problem out.
That's EXACTLY what you need!
What values of x will give a zero denominator?
What values of x will give something negative under the square root?
FAQ: Finding the Domain of a Function
What is the definition of a function's domain?
The domain of a function is the set of all possible input values (or independent variables) for which the function is defined. It is the set of values that can be used as input to the function to produce an output.
How do you determine the domain of a function algebraically?
To determine the domain of a function algebraically, you must identify any values that would result in an undefined output. These may include division by zero, square roots of negative numbers, or logarithms of non-positive numbers. Once these values are identified, the domain is the set of all real numbers excluding these values.
Can a function have more than one domain?
No, a function can only have one domain. The domain is a set of input values that correspond to unique output values. If a function has multiple domains, it would mean that a single input value could produce multiple output values, which goes against the definition of a function.
What are the different types of domains?
The most common types of domains are the natural domain, which includes all real numbers for which the function is defined, and the restricted domain, which is a subset of the natural domain and excludes certain values that would result in an undefined output.
Can a function have an empty domain?
Yes, a function can have an empty domain if there are no input values for which the function is defined. This can occur when there are restrictions on the domain, such as the square root of a negative number, or when the function is undefined for all real numbers.
