Finding the eigenspace for this value of lambda
  • Thread starter Thread starter member 731016
    Lambda Value
member 731016
Please see below
Please see below
For this,
I don't understand how they solved,
Because we would have to take the inverse of both side which would give the inverse of the matrix ##2 \times 2## matrix on the left hand side which dose not have an inverse.
Dose anybody please know how they did this?
Many thanks!
In equation form, we have ##-6 x +6 y =0 \iff x - y = 0## (dividing both sides by -6) for the first line. Likewise for the second line, ##5 x -5 y =0 \iff x - y = 0## (dividing both sides by 5). So both equations say the same thing.
Now you can see what they were doing in matrix form and why there is no need to include ##x## and ##y## where they were manipulating the augmented matrices. It really represents the same thing.
Likes member 731016
There isn't a single solution for the eigenvector(s). That's why you can't invert that matrix. That's how it is with eigenvalue problems. In fact, that's how you find the eigenvalues with the characteristic equation |AI|=0, i.e. find λ that makes AI not invertable.
Likes member 731016
Again, that's "does".
Your thread title indicates that you are to find the eigenspace for a matrix. IOW, the set of all nonzero vectors x (in ##\mathbb R^2## here) such that Ax = λx, or equivalently, ##(A - \lambda I)\mathbf x = \mathbf 0##.
In order for x to be nonzero, the determinant of ##A - \lambda I## must be zero.
I'm guessing that your textbook is probably explaining this. Are you skipping over parts of the textbook?
Likes member 731016 and berkeman
Thank you @FactChecker , @DaveE and @Mark44!
I think I understand now :)
@Mark44, yes, sadly, I have to skip over parts of the textbook as the course jumps from one topic to another. Also sorry I did not see the dose again.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
