Finding the elements of these sets
In summary, the conversation was about specifying the possible values of n in a mathematical expression. The correct answer was {##2\pi n, n \in \mathbb{Z}##}.
Math100
802
222
Write each of the following sets by listing their elements between braces.
None.
Can anyone please check/confirm my answers? I've shown my work and I boxed around all of my answers. Thank you.
It's good except the last one, where you should specify what values n can take.
Likes Math100
But how should I specify what values n can take? Any hints?
Can n be an arbitrary rational number, such as 1/2? Can n be any real number? Some details on the possible values of n are what @FactChecker is looking for.
No, n cannot be 1/2.
Just say what set of values n can take. Like {##2\pi n, n \in ?##}
Likes Math100
{...,-4pi, -2pi, 0, 2pi, 4pi, ...}
So for ##2\pi n## to take on those values, what set of numbers does n belong to? That's what we're trying to get you to tell us.
Likes Math100
{..., -2, -1, 0, 1, 2, ...}
Is that the right answer?
Also known as the integers, ##\mathbb{Z}##
So a good expression of the answer is {##2\pi n, n \in \mathbb{Z}##}
Likes Math100
Thank you so much!
Likes berkeman
FAQ: Finding the elements of these sets
What are sets?
Sets are collections of distinct objects or elements that are grouped together based on a common characteristic or property. They are often represented using curly braces {} and each element is separated by a comma.
How do you find the elements of a set?
To find the elements of a set, you can either list them out or use set-builder notation. In set-builder notation, the elements are described using a rule or condition that they must satisfy to be included in the set.
What is the cardinality of a set?
The cardinality of a set is the number of elements in the set. It is represented by the symbol |A|, where A is the set. For example, if a set A = {1, 2, 3}, then |A| = 3.
How do you determine if an element is in a set?
To determine if an element is in a set, you can check if the element satisfies the condition or rule set by the set-builder notation. If the element satisfies the condition, then it is included in the set. If not, then it is not part of the set.
Can a set have duplicate elements?
No, sets do not have duplicate elements. Each element in a set must be unique and cannot be repeated. If there are multiple instances of an element, it is still considered as one element in the set.
