MHB Finding the Equation of a Line Given Two Points
  • Thread starter Thread starter mathdad
To find the equation of the line passing through the points (6, -3) and with a y-intercept of 8, start with the slope-intercept formula y = mx + b, where b = 8. The y-intercept can be represented as the point (0, 8). The slope m is calculated using the formula m = (y2 - y1) / (x2 - x1), substituting the known values. After determining the slope, plug m and b into the slope-intercept equation to find the complete equation of the line. This method effectively utilizes both points and the y-intercept to derive the line's equation.
mathdad
Find an equation of the line that passes through (6, -3) and has y-intercept 8.
I know y = mx + b is the slope-intercept formula. In the formula, b represents the y-intercept. I also see that 8 is given to be b in this case.
The y-intercept can be written as (0, 8).
Do I now find the slope m?
Afterward, use one of the points and m to plug into the point-slope formula. Finally, I must isolate y.
Is this right?
Mathematics news on Phys.org
Like you, I would begin with the slope-intercept form of a line:
$$y=mx+b$$
We are given $b=8$, and we know two points on the line, so we can compute the slope $m$:
$$m=\frac{8-(-3)}{0-6}=$$?
Then, just plug in the values for $m$ and $b$. :)
$$y=mx+b$$
I can take it from here. Thanks.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
