MHB Finding the Equation of a Line through a Point and Circle Center?
  • Thread starter Thread starter mathdad
To find the equation of a line through the point (3, -5) and the center of the circle defined by 4x^2 + 8x + 4y^2 - 24y + 15 = 0, the circle must first be expressed in standard form by completing the square. The center of the circle is identified as the point (h, k). The slope of the line can be calculated using the coordinates of (3, -5) and (h, k). The point-slope formula can then be applied to derive the equation of the line. Understanding these steps confirms the correct approach to solving the problem.
mathdad
Find an equation of the line passing through (3, -5) and through the center of the circle 4x^2 + 8x + 4y^2 - 24y + 15 = 0.
Does this problem involve completing the square?
Must I express the above circle in the form (x - h)^2 + (y - k)^2 = r^2?
The center is the point (h, k), right?
I must then find the slope of the points (3, -5) and (h, k), right?
I then use the point-slope formula and proceed as usual.
Mathematics news on Phys.org
Yes, you are correct. You may use the following equation of the line passing through (x1, y1) and (x2, y2).
\frac{y-y_1}{y_2-y_1}=\frac{x-x_1}{x_2-x_1}
if y2 - y1 = 0, then the equation is y = y1. If x2 - x1 = 0, then the equation is x = x1.
Cool. Good to know that I understood the question correctly.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
