Finding the equation of a plane given 2 lines and a point
In summary: You can use those three points to find the equation of the plane.In summary, the problem involves finding the equation for a plane that contains the intersection of two given planes and a given point not on either of the planes. This can be done by finding the parametric equations for the line of intersection, determining a vector in the direction of the line, and using it with the given point to find the equation of the plane.
Potatochip911
318
Find the equation for the plane containing the lines:
x-y+2z=4
2x+y+3z=6
and the point: (1,-2,4)
A(x-xi)+B(y-yi)+C(z-zi)=0
First I wrote down the vectors from the line equations,
V1=<1,-1,2>
V2=<2,1,3>
After this I did the cross product to get the perpendicular vector and I ended up with
Vp=<-5,1,3>
now using the equation and the point given at the start
-5(x-1)+1(y+2)+3(z-4)=0
-5x+y+3z-5=0
The correct answer is: 8x+13y+9z-18=0
Potatochip911 said:
x-y+2z=4
2x+y+3z=6
These are planes, not lines. Coulld you check the problem formulation?
I rechecked it and it says "containing the line x-y+2z=4 and 2x+y+3z=6 and the point (1,-2,4)" so apparently they're both the same line?
They are both planes. However, planes cross in a line (or they are parallel, which is not the case here). Thus, there is only one line in the problem. The vectors V1 and V2 are normal to the two planes and so they are both orthogonal to the line. Taking the cross product gives you a vector which is therefore the tangent vector of the line and using that as a normal vector of your plane gives you a plane which is orthogonal to both of the original planes, i.e., it is orthogonal to your line and does not contain it.
I suggest you try to figure out how you can end up with a vector which is orthogonal to both the line and to the displacement between any point on the line and the point (1,-2,4).
You can check whether or not your final equation is correct by inserting some points from the line into your formula and see if it is fulfilled or not.
It seems as though I have to solve for the parametric equations, is it not possible to do this with the cross product?
You are determined to use the cross product, aren't you? You will but not to find the equation of the line. You are given the two planes x-y+2z=4 and 2x+y+3z=6. You have two equations in three unknowns. You can solve for any two of them in terms of the third. Use that third unknown (or some multiple of it) as parameter to get parametric equations for the line of intersection of the two planes. Take the vector in the direction of that line and the vector from some point on that line to the initially given line and find the cross product of them.
Okay I managed to get the answer but now I am just really confused by the theory of all this. So because the point given to me (1,-2,4) is not on either of the planes I need to solve for a point that is on both planes and then find the vector that will move my point onto the plane?
I'm not sure what you mean by "move my point onto the plane". There is no "moving" in this problem. Two planes intersect in a line. There exist a unique plane containing any given line and point not on the line. Equivalently, you could choose any two points that lie on the line. A plane will contain a line if and only if it contains two points on the line. Those two points, together with the given point give you three points on the plane. There exist a unique plane containing any three non-collinear points.
Related to Finding the equation of a plane given 2 lines and a point
1. What is the equation of a plane?
The equation of a plane is a mathematical expression that describes a flat, two-dimensional surface in three-dimensional space. It typically takes the form of Ax + By + Cz + D = 0, where A, B, and C are the coefficients of the variables x, y, and z, and D is a constant.
2. How do you find the equation of a plane given 2 lines and a point?
To find the equation of a plane given 2 lines and a point, you can use the point-slope formula. First, find the slope of the two lines using their equations. Then, use the point-slope formula with the given point and slope values to find the equation of the perpendicular line that passes through the given point. Finally, use the equations of the two lines and the perpendicular line to find the equation of the plane.
3. Can you find the equation of a plane with only 2 lines?
No, you need a third point or line in order to uniquely determine the equation of a plane. With only 2 lines, there are infinite possible planes that can pass through them.
4. Can the equation of a plane be written in different forms?
Yes, the equation of a plane can be written in different forms such as standard form, slope-intercept form, and point-normal form. However, they all represent the same plane in three-dimensional space.
5. How can the equation of a plane be used in real-life applications?
The equation of a plane has many real-life applications, such as in engineering and architecture, where it is used to model and design structures in three-dimensional space. It is also used in computer graphics to render three-dimensional objects on a two-dimensional screen. Additionally, the equation of a plane is used in physics to calculate the force and motion of objects in three-dimensional space.
