Finding the Equations of Tangent Lines to a Circle
  • MHB
  • Thread starter mathdad
In summary, the equations of the tangent lines to the circle x^2 + y^2 = 169 at the points (5, 12) and (5, -12) are y = (-5/12)x + (169/12) and y = (5/12)x - (169/12), respectively. The method used to find these equations involves finding the slope of the radius from the center to the point of tangency and then using the negative reciprocal of this slope to find the slope of the tangent line. The point-slope formula is then used with the given point of tangency to find the equations of the tangent lines.
mathdad
1,283
Tangents are drawn to the circle x^2 + y^2 = 169 at the points (5, 12) and (5, -12). Find the equations of the tangents.
I need the steps.
I know the circle has a radius of sqrt{169} or 13.
Mathematics news on Phys.org
I need the steps.
Okay, let's take this step by step...first, where is the center of the circle?
The center is (0, 0) and radius 13.
Okay...good! (Yes)
Now, how does the radius of a circle (drawn from the center to the point of tangency) relate the the line tangent to the circle? If you need to, draw a circle and then draw a radius, and the line tangent to the circle where the radius meets the circle.
The distance from the center to the point of tangency is 13.
The radius from the center to the point of tangency is perpendicular.
Yes, and so you need to find the slopes of the given radii, and then use the negative reciprocal of the slope of the radius as the slope of the tangent line, and the given point of tangency in the point-slope formula to find the equations of the tangent lines. :D
Ok. I will work on this one tomorrow before going to work and post my work for both equations.
We have:
radius = 13
points (5, 12), (5, -12) and (0, 0)
Let m_1 = slope 1
m_1 = (5 - 0)/(12 - 0)
m_1 = 5/12
y - 12 = 5/12(x - 5)
y = (5/12)x - (25/12) - 12
y = (-12/5)x - (169/12)
Is this one of the equations of the tangents?
Let m_2 = slope 2
m_2 = (-12-0)/(5-0)
m_2 = -12/5
y -(-12) = (-12/5)(x - 5)
y + 12 = (-12/5)x + 60/5
y = (5/12)x + 12 - 12
y = (5/12)x
Is this the second equation?
Let's work a more general version of the problem...that is, to find the equation of the line tangent to the circle:
\(\displaystyle (x-h)^2+(y-k)^2=r^2\)
at the point on the circle:
\(\displaystyle \left(x_1,y_1\right)\)
where:
\(\displaystyle y_1\ne k\)
When $y_1=k$, then we know the tangent line is simply $x=x_1$.
The slope of the line will be:
\(\displaystyle m=\frac{h-x_1}{y_1-k}\)
And so, using the point-slope formula, the tangent line is:
\(\displaystyle y=\frac{h-x_1}{y_1-k}\left(x-x_1\right)+y_1\)
Arranged in slope-intercept form, we have:
\(\displaystyle y=\frac{h-x_1}{y_1-k}x+\frac{x_1-h}{y_1-k}x_1+y_1\)
For the given problem, we have:
\(\displaystyle (h,k)=(0,0)\)
And so, our formula reduces to:
\(\displaystyle y=-\frac{x_1}{y_1}x+\frac{x_1}{y_1}x_1+y_1=-\frac{x_1}{y_1}x+\frac{x_1^2+y_1^2}{y_1}=-\frac{x_1}{y_1}x+\frac{r^2}{y_1}\)
The first point is:
\(\displaystyle \left(x_1,y_1\right)=(5,12)\)
And so the tangent line is:
\(\displaystyle y=-\frac{5}{12}x+\frac{169}{12}\)
The second point is:
\(\displaystyle \left(x_1,y_1\right)=(5,-12)\)
\(\displaystyle y=\frac{5}{12}x-\frac{169}{12}\)
Let's plot the circle and the two lines to verify:
[DESMOS=-34.23893796773567,51.449953593644956,-15.304682349252822,14.422600065796832]x^2+y^2=13^2;y=-\frac{5}{12}x+\frac{169}{12};y=\frac{5}{12}x-\frac{169}{12}[/DESMOS]
I undetstand the question better now than when I first read it in the textbook.
where:
The first point is:
Check your private message.
FAQ: Finding the Equations of Tangent Lines to a Circle
What are equations of the tangents?
Equations of the tangents are mathematical expressions that represent the slope of a curve at a specific point. They describe the rate of change of a curve at a given point and can be used to find the slope of a line tangent to the curve.
How do you find the equation of a tangent line?
The equation of a tangent line can be found by taking the derivative of the curve at the given point and plugging in the coordinates of the point into the derivative. This will give the slope of the tangent line. Then, using the point-slope form of a line equation, the equation of the tangent line can be written with the slope and point.
What is the point-slope form of a line equation?
The point-slope form of a line equation is y - y1 = m(x - x1), where m is the slope of the line and (x1, y1) is a known point on the line. This form is useful for finding the equation of a tangent line since the slope and point can be easily determined.
How are equations of the tangents used in real life?
Equations of the tangents have many practical applications, such as in physics, engineering, and economics. They can be used to calculate the velocity of a moving object, the rate of change of a chemical reaction, or the marginal cost of production.
Can equations of the tangents be used for any type of curve?
Yes, equations of the tangents can be used for any type of curve, including linear, quadratic, exponential, and trigonometric curves. The only requirement is that the curve is differentiable at the given point, meaning that it has a well-defined derivative at that point.
