Finding the exact value of an integral without calculator
In summary, the task is to find the exact value of the integral ∫-55 √25-x2 dx without using a calculator. The hint suggests considering the geometric significance of the definite integral. The attempt at a solution involves using the substitution method, but the resulting answer is incorrect. The graph y=\sqrt{1-x^2} represents a semi-circle, and the area under the curve is half the area of a circle of radius 5. Therefore, the correct solution is (1/2)∏52.
rubenhero
42
Find the exact value of: ∫-55 √25-x2 dx without using your calculator. (Hint: Consider the geometric significance of the definite integral.)
integrate and find antiderivative and evaluate at A and B.
-55 √25-x2 dx
=[2/3(25-x2)3/2*2x]-55
=(2/3(25-52)3/2*2*5)-(2/3(25--52)3/2*2*-5)
=0-0
I don't think I got the right answer, I thought i always find the antiderivative to integrate.
Is there something I am doing wrong? Any help would be appreciated!
Yes it's definitely wrong, and also it's very hard to follow what you did to tell you where you went wrong.
What does the graph [itex]y=\sqrt{1-x^2}[/itex] represent?
And have you learned about using substitutions to solve integrals yet?
thank you for your quick response,
is [itex]y=\sqrt{1-x^2}[/itex] a circle?, oh a circle isn't continuous so i can't do antiderivatives?
i have learned substitutions but if i let u be 25-x2, du = -2x dx, i would have to put a (-1/2x) in front of the integral, then integrate u to be (2/3)u3/2, wouldn't i still end up with (25-(52))-(25-(-5)2))
would i just use the area of a circle formula ∏r2 for this problem?
A circle would be [itex]x^2+ y^2= 1[/itex]- y can be both positive and negative. [itex]y=\sqrt{1- x^2}[/itex] requires that y be non-negative- it is a semi-circle.
Yes, that is the whole point of hint- the area under the semi-circle is half the area of a circle of radius 1.
thank you, that makes sense now. the radius is 5 so it would be (1/2)∏52.
FAQ: Finding the exact value of an integral without calculator
What is the process for finding the exact value of an integral without a calculator?
To find the exact value of an integral without a calculator, you need to use integration techniques such as substitution, integration by parts, or partial fractions. These techniques involve manipulating the integral to make it easier to solve and then using mathematical principles to find the exact value.
Can all integrals be solved without a calculator?
No, not all integrals can be solved without a calculator. Some integrals require advanced techniques or involve special functions that cannot be solved without a calculator. In these cases, approximate methods or numerical integration may be used to find an approximate value.
How accurate is finding the exact value of an integral without a calculator?
Finding the exact value of an integral without a calculator can be extremely accurate if the techniques used are correct and the calculations are done carefully. However, human error can still occur, so it is important to double-check the calculations for accuracy.
Is it necessary to use a calculator for integrals?
No, it is not necessary to use a calculator for integrals. Many integrals can be solved using basic techniques and knowledge of mathematical principles. However, a calculator can be helpful for checking answers or solving more complex integrals.
Are there any tips for finding the exact value of an integral without a calculator?
Yes, there are a few tips that can make finding the exact value of an integral without a calculator easier. These include breaking the integral into smaller, simpler integrals, using trigonometric identities, and carefully checking the calculations for accuracy. It is also helpful to have a strong understanding of basic integration techniques and mathematical principles.
