Finding the exact value of cos(arcsin())
  • Thread starter opus
  • Tags
    Value
In summary, the exact value of y = cos(arcsin(5/11)) can be found by recognizing that the inverse sine function has a range of [-π/2, π/2], meaning that the angle θ must be in the first quadrant. This allows us to conclude that cos(θ) will be positive and thus y = cos(arcsin(5/11)) is a positive value.
opus
131
Find the exact value of ##y=cos\left(arcsin \frac {5} {11} \right)##
I'm stuck at square one. I know that I must evaluate arcsin first, which will give me an angle θ. From that angle, I can take the cosine of it and that much makes sense.
However, in this "guided homework problem" it is stating information that doesn't seem so obvious to me. I've posted a picture.
In the guided problem, it states that θ is in the range of the inverse function. I don't see how this is the case. The range of the inverse function is in the inclusive range of ##\frac {-π}{2}## and ##\frac {π}{2}##. In looking at the problem, I can tell that sine is positive, but that doesn't imply that it's in range as it could be in quadrant II.
What should I be looking for?
No, quadrant II is π/2<θ<π. . The range of the inverse sine function is -π/2 < θ < π/2 . Here cos(θ) is positive.
Likes opus
Never mind trying to find the angle ##\theta##; it won't really help you solve the problem. All you need to figure out is whether or not ##\cos \theta## will be ##> 0## or ##< 0##.
Likes opus
Since 5/11 is positive, that means that ##\theta## lies between 0 and ##\pi/2##; i.e., is in the first quadrant.
Likes opus
opus said:
In the guided problem, it states that θ is in the range of the inverse function. I don't see how this is the case. The range of the inverse function is in the inclusive range of ##\frac {-π}{2}## and ##\frac {π}{2}##. In looking at the problem, I can tell that sine is positive, but that doesn't imply that it's in range as it could be in quadrant II. What should I be looking for?
You're thinking of the solutions to ##\sin\theta = \frac {5}{11}##, which has solutions in quadrant I and II. That's not the same as ##\theta = \arcsin \frac{5}{11}## because the range of the arcsin function corresponds to angles in only the first and fourth quadrants.
To make arcsin a function, it can only map 5/11 to one of the two possible values (between 0 and ##2\pi##) for ##\theta## for which ##\sin\theta = \frac {5}{11}##. The arcsin function is defined so that the value it returns is the one in the first quadrant and not the second.
Likes opus
Draw a right triangle. What is the adjacent side?
Likes WWGD, opus and Merlin3189
... because the range of arcsin() is ##[-\frac \pi 2, \frac \pi 2]##.
Likes opus
I think you mean the range, right? The domain is [-1,1].
Likes opus
Yes, that's what I meant. I've edited my earlier response.
Likes opus
So in looking at arcsin ##\left(\frac {5} {11}\right)##, I know that y is a positive value, which limits my options to either quadrant I or quadrant II. But since we are taking the arcsin, who's range is [##\frac {-π}{2} , \frac{π}{2}##], I can conclude that it has to be in quadrant I, because quadrant II would be out of the range of arcsin. So does this hold true for any value given? ##\frac {11}{2}##? ##\frac {1}{50}##? ##\frac {777}{800}##? If I take the arcsin of any value, it will produce an angle in the allowable range? Or is this problem cherry picked to be in the range of arcsin?
Try it out. First, think about what the domain of arcsin(x) is. Then try the values of x at the endpoints of the domain and some in the middle as inputs to the function. What do you get for arcsin(x)?
Likes opus
What's the definition of the range of a function?
Likes opus
If working with real functions, you can only take arcsin of a value in [-1,1]. Each will return a unique value in [-π/2,π/2].
Likes opus
Because the range for arc sin (5/11) is already given as (-pi/2, pi/2) theta is just first quadrant. Just find cos theta for that theta for which is sin theta = 5/11. I do not think there is any problem
Likes opus
Going that route, I do not see how you will satisfy:
Try @robphy's hint in post #7 (but whether that leads to an exact value that's any more a solution than what you started with is a matter of opinion).
Likes opus
Do you know that [tex]1=cos^2(A) + sin^2(A)[/tex] for any real number "A" ?
So [tex]1=cos^2(arcsin(\frac{5}{11}) + sin^2(arcsin(\frac{5}{11}))[/tex], from here it is quite straight forward, isn't it?
Likes opus
This is what I was hoping would be the response of the OP to my message #4, but I did not want to give away the whole solution.
Likes opus
Not for me.
This just proves that 1 = 1, when I plug the numbers into my calculator.
@opus , did you ever figure this out?
ps. It took me a couple of days to figure out the solution. I think I used a different method than everyone else so far.
Likes opus and Let'sthink
Yes, one does never know where to put the line between "just a hint" and "almost solving the whole thing". :-)
Likes opus
OmCheeto said:
Not for me.
Don't use a calculator for the [itex]\cos^2[/itex] term... think of it as [itex]C^2[/itex], the square of the unknown.
Don't use a calculator for the [itex]\sin^2[/itex] term... can you evaluate it without a calculator?
Likes opus
OmCheeto said:
Not for me.
You don't need to use any calculator. They ask you to calculate, say, "A" and you already know that [tex]A>0[/tex] and that [tex]1 = A^2 + \left(\frac{5}{11}\right)^2[/tex], I think it is quite straight forward from here...don't you think? :-)
Likes opus
robphy said:
Don't use a calculator for the cos2\cos^2 term... think of it as C2C^2, the square of the unknown.
Don't use a calculator for the sin2\sin^2 term... can you evaluate it without a calculator?
A>0​
A>0 and that
1=A2+(511)2​
1 = A^2 + \left(\frac{5}{11}\right)^2, I think it is quite straight forward from here...don't you think? :-)
As I stated, I figured out the solution, in two days, meaning Feb 24th, meaning 8 days ago.
At first I cheated, and googled.
This gave me a solution, but I didn't understand "why" it worked.
The numerous hints didn't help either.
Although, in hindsight, I understand where everyone was coming from.
Being not the OP, and having had my "epiphany", I'll wait for opus to respond.
Likes opus
I think opus did that, in post #2
In retrospect, yours was the best hint, IMHO.
Equations might yield the answer, but a picture is worth a thousand "Ah ha!"s.
Likes opus
Shoot! That's a lot of great posts! Apologies for the very late response. I've had the worst flu of my life over the past two weeks.
I think I had a faulty idea of the inverse Trig functions, but while I had the flu I watched about 20 different videos on them :DD I think I've got a much better understanding of them now. What I didn't fully grasp was that we take the sine of angles and arcsin of values which made things quite confusing. In thinking about the domain to keep the function one-to-one, I thought about a similar idea in Algebra but with quadratic graphs and how we need to restrict the domain to make them one-to-one.
I really appreciate everyone's help. I've got a great teacher but this book is really terrible. There are missing words and typos throughout and I tried to fill in the blanks with my own intuition and I filled in the blanks with my own faulty information. I downloaded an OpenStax book and have been going off of that and now things are running smoothly.
I think Op has already got the answer. But has he really understood why the range has been specified for the inverse function? Someone tried to tell you that but have you understood. Hint for that you need to know and understand the definition of "function"
So the domain for the sine function is restricted to [-π/2, π/2] so that it will be one-to-one and can have an inverse. If it wasn't restricted, we could have an input value for the inverse map to more than one output value. The range is remains the same at [-1,1].
For the arcsin function, what was the range from the sine function is now the domain for the arcsine, in this case [-1,1] is the domain of arcsine. The range for the arcsin is going to be [-π/2, π/2] because this is what we restricted our sine function domain to, and the range for the arcsin is the domain of the sine function.
Did I explain this correctly?
For the arcsin function, what was the range from the restricted sine function is now the domain for the arcsine, in this case [-1,1] is the domain of arcsine. The range for the arcsin is going to be [-π/2, π/2] because this is what we restricted our sine function domain to, and the range for the arcsin is the domain of the restricted sine function.
That is essentially correct.
I would modify that just a bit, as I have suggested with the additional red text above.
The result of restricting the domain of a function is a new, different function.
Likes opus
opus said:
So the range for the arcsine function is restricted to [-π/2, π/2] so that it will be one-to-one and sine function can have an inverse. If it wasn't restricted, we could have an input value for the inverse map to more than one output value. The domain remains the same at [-1,1].
For the arcsin function, what was range for the sine function is now the domain for the arcsine, in this case [-1,1] is the domain of arcsine. The range for the arcsin is going to be [-π/2, π/2] y?
It appears you have understood but your statements needs to be correctly worded you have made a slight jumble. I tried to correct it in your quote.
Likes opus
Ok thank you for responding. That is more clear and precise. I felt myself rambling and talking in circles trying to explain it, but your edits are much better. Thank you again!
  • #31
Just to test your understanding please tell me the unrestricted domain of the sine function. When the domain is not restricted is it one-one or many one function? Also state the definition of a function using all terms such as "domain" correctly.
Likes opus
  • #32
The graph of the sine function goes on forever in both the positive and negative directions and we can make as many positive or negative unit circle rotations as we’d like. For these reasons the unrestricted domain of the sine function is[-∞,∞]. This would be a one to many function where an infinite amount of inputs would map to a single output. For example, (π/2) and (-3π/2) would both map to 1.
For the last part, do you mean something like f is a function that maps an input,x, to one and only one output, y, for all values of x in the domain of f? I didnt look this one up because I wanted to attempt to define it on my own to test my understanding. It doesn't seem wholly sufficient.
  • #33
opus said:
The graph of the sine function goes on forever in both the positive and negative directions and we can make as many positive or negative unit circle rotations as we’d like. For these reasons the unrestricted domain of the sine function is[-∞,∞]. This would be a many to one function where an infinite number of inputs would map to a single output in a limited range. For example, (π/2) and (-3π/2) would both map to 1.
Again you are almost right and like earlier have made some terminological mistakes! I correct them by writing in red. Your definition is almost correct. But just I write it again in so called my words. Function is a rule which associates with EVERY element in the domain set, with a UNIQUE element in the Range set. That is why a function can be one one or many one (but never one many, because then it will not be function at all) So the inverse of a many one function cannot be a function unless we restrict the range set and make it one one. This problem illustrates these ideas.
Likes opus
  • #34
Ah that is much more precise. I definitely feel much better about my understanding of functions after going over this. Thank you so much.
Related to Finding the exact value of cos(arcsin())
1. What is the formula for finding the exact value of cos(arcsin(x))?
The formula for finding the exact value of cos(arcsin(x)) is cos(arcsin(x)) = √(1-x^2).
2. Can you explain the meaning of cos(arcsin(x))?
Cos(arcsin(x)) is the inverse trigonometric function that represents the cosine of an angle whose sine is x. In simpler terms, it is the ratio of the adjacent side to the hypotenuse in a right triangle with a given value of x as the opposite side.
3. How do you find the exact value of cos(arcsin(x)) using a calculator?
To find the exact value of cos(arcsin(x)) using a calculator, you can use the inverse trigonometric function button (usually denoted as "sin^-1" or "arcsin") followed by the value of x and then press the cosine button (usually denoted as "cos"). Make sure your calculator is set to the correct mode (degrees or radians) before performing the calculation.
4. What is the range of values for cos(arcsin(x))?
The range of values for cos(arcsin(x)) is between -1 and 1, inclusive. This is because the cosine function has a range of -1 to 1, and the arcsine function produces values that are within this range.
5. Can you provide an example of finding the exact value of cos(arcsin(x))?
For example, if we want to find the exact value of cos(arcsin(0.5)), we can use the formula cos(arcsin(x)) = √(1-x^2). Plugging in the value of x as 0.5, we get cos(arcsin(0.5)) = √(1-0.5^2) = √(1-0.25) = √(0.75) ≈ 0.866. Therefore, the exact value of cos(arcsin(0.5)) is approximately 0.866.
