Finding the force of repulsion between two point charges
In summary, the homework statement asks for the force of repulsion between two point charges of +1C and +3C. On which charge is the greater force? The Attempt at a Solution provides a solution of 2.682 x 1010 N.
RabbitWho
153
Hello! So this is going into physics because it is a physics problem, but it is maths that is the real problem. So if you came here to help someone with physics and not maths I'm sorry.
1. Homework Statement
Find the force of repulsion between two point charges of +1C and +3C if they are placed 1 m apart in a vacuum. On which charge is the greater force?
So here is what I know
ε=8.9x10-12
π = 3.14
d = 100 cm
q1 = 1
q2 = 3
cats are soft and warm
here is the formula I have to use
F= 1/4πε0 Q1 Q2/d2
I can't find pi on the thing. Is this supposed to be pi: π?It looks like a Russian L. This is hard enough without alternate fonts.
This is going to be my fourth time trying this.
The correct answer should be 2.682 x 1010
Am I right in thinking that 10-2 x 10-2 =10-4? It's just 100 x 100 = 10,000, right?
1 (1 x 10 -6) ( 3x 10-6)
_______________________________________________
4π(8.9 x 10-12)(100)
Here's my attempt at solving what's above the line:
3 x 10 -12
I'm less confident about what's below. Do I multiply pi by 4 first?
3 x 10 -12
12.5(8.9 x 10-12)(100)
Like that?
Am I right in thinking that 8.9 x 10-12 x 100 = 8.9 x 10-14?
So now I have
3 x 10 -12
12.5 (8.9 x 10-14) 3 x 10 -12
106.8 x 10-14)
So there are 2 zeros there that I've put in bold that I think I have to get rid of, and I'm going to add them onto that little -14
1.068 x 10-16. Is that right? 3 x 10 -12
1.068 x 10-16
Now there are loads of zeros above and below the line, am I right in thinking I can cross them out? the difference between -12 and -16 is 4, so I'll get rid of the -12 all together and leave -4 below.
3 x 10
1.068 x 10-4
It occurs to me that 3 x 10 is 30 and that 1.068 x 10000 is 10680
30
______
10680
= 0.00289575289 N
Low and behold.. not the right answer. It is the second time I got this same answer though so at least that's something, I suppose.
I'd really appreciate it if, even something that would inevitably cause me to get the wrong answer happened very early on, you'd tell me if there were other silly things I did with the numbers later.
Thank you!
Hi Rabbit:
I think your problem may be with units. I suggest you rewrite each of your numeric equations and variable definitions, and include the corresponding units.
Hope this helps.
Regards,
Buzz
Yes.
##10^{-2}= \frac{1}{100}##. So, ##10^{-2} \times 10^{-2} = \frac{1}{100} \times \frac{1}{100} = \frac{1}{100 \times 100} = \frac{1}{10000} = 10^{-4}##
The statement of the problem gives the charges as 1 C and 3 C, not 1 x 10-6 C and 3 x 10-6 C.
Also, if you are using Coulombs for the charge, then you are working in the SI system of units. In this system of units, the unit of length is the meter, not the centimeter. So, you will need to convert 100 cm to meters.
3 x 10 -12
3 x 10 -12
Like that?
When you multiply several numbers together, it does not matter what order you multiply them. So, yes, you can multiply π by 4 first.
No. Note that 100 = 102.
So, 10-12 x 100 = 10-12 x 102 = 10-12+2 = 10-10.
3 x 10 -12
106.8 x 10-14)
You are right that you want to add 2 to -14. But that doesn't give you -16.
3 x 10 -12
1.068 x 10-16
3 x 10
1.068 x 10-4
When you combine the -12 and -16 to get 4, you have used up all the factors of 10 in the numerator. So, your numerator becomes 3, not 3 x 10.
Likes RabbitWho
TSny said:
Yes.
cool
Ah! Sorry, this was a big mistake. I was looking at the sample method, where they were using microunits
This is confusstipating because in the sample the book has an example with 50 cm and uses 50 as d in the sample method, not 0.5.. But ok!
cool :)
Ah yes thank you. Was confusing -12 with 12
doi *smacks head*
Thank you! :) Thank you so much!
[/B]
ε=8.9x10-12
π = 3.14
d = 100 cm
q1 = 1
q2 = 3
F= 1/4πε0 Q1 Q2/d2
10-2 x 10-2 =10-4
1 x 3
4π(8.9 x 10-12)(1)3
4π(8.9 x 10-12)(1)
12.5(8.9 x 10-12)(1)
111.25 x 10 -12)
___________________
1.125 x 10 -10)
=2.67 -10N ... X
What am I doing wrong?
So sorry, I did try twice before submitting, and I went over everything for a good 20 minutes.
Everything is ok except for the very last step. You did not correctly treat the 10-10 in the denominator in arriving at your final answer.
What is ##\frac{1}{10^{-10}}##?
Related to Finding the force of repulsion between two point charges
1. What is the formula for calculating the force of repulsion between two point charges?
The formula for calculating the force of repulsion between two point charges is F = k * (q1 * q2) / r^2, where k is Coulomb's constant (8.99 x 10^9 N*m^2/C^2), q1 and q2 are the magnitudes of the two point charges, and r is the distance between them.
2. How does the distance between two point charges affect the force of repulsion?
The force of repulsion between two point charges is inversely proportional to the square of the distance between them. This means that as the distance increases, the force of repulsion decreases. Similarly, as the distance decreases, the force of repulsion increases.
3. Can the force of repulsion between two point charges be negative?
No, the force of repulsion between two point charges can never be negative. It is always a positive value, indicating a repulsive force between the charges.
4. How does the magnitude of the point charges affect the force of repulsion?
The force of repulsion between two point charges is directly proportional to the product of the magnitudes of the two charges. This means that as the magnitude of one or both charges increases, the force of repulsion also increases.
5. What is the unit of measurement for the force of repulsion between two point charges?
The unit of measurement for the force of repulsion between two point charges is Newtons (N), which is a unit of force in the International System of Units (SI).
