Finding the frequency of a string based on Mass and Tension
The discussion revolves around calculating the frequency of a string using the formula ƒ=sqrt(T / u) / 2L. The user calculated tension (T) as 490N and linear mass density (u) as 0.04285 kg/m, leading to a frequency of 76.38Hz. There is confusion regarding the division by 2L, questioning if it was necessary or if the original answer omitted this step. Additionally, the user raises a point about whether the wave can freely vibrate over the entire 70 cm length, considering the effects at the pulley. Clarification on these calculations and assumptions is sought.
SoundsofPhysics
Thread moved from the technical forums to the schoolwork forums
I saw the following problem in a test I was reviewing:
I don't understand how they got their answer. I used the formula: ƒ=sqrt(T / u) / 2L where f is the frequency of the string, T is the tension, u is the linear mass density, and L is the length of the string.
I got:
T = mg = 50 * 9.8 = 490N
u = m/l = 3/7 g/cm = 0.04285 kg/m
L = 70cm = 0.7m
Therefore f = sqrt(490 / 0.04285) / 1.4 = 106.93 / 1.4 = 76.38Hz. I see that they got their answer from the first part, but did they forget to divide by 2L, or was I not supposed to do that? Thanks!
Can the wave freely vibrate over the entire 70 cm length? Think about what happens at the pulley.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 26 ·
