Finding the gain coefficient at line centre for a HeNe Laser
In summary, the conversation discusses the calculation of the gain coefficient for a helium neon laser by using the Füchbauer–Ladeberg formula and Einstein coefficients. The gain coefficient is defined as the change in intensity over distance and is related to the spontaneous emission lifetime and the Lorentzian lineshape representing the lasing transition. The resulting calculation for the gain coefficient is 63772, which may have some minor errors but still gets the point across. The conversation also acknowledges the lack of information available on this topic and suggests looking into the details of the helium neon laser for more information.
MarkNormand99
The upper lasing transition of neon in a helium-neon laser has a spontaneous
radiative decay to the lower laser level with a transition probability of 3.39 × 10^7
s^−1
Determine the gain coefficient at line centre if the density of the upper lasing state for the helium neon laser is 10^18 m−3.
Assume the lower states population is negligible
There were no relevant equations given in the question
I have found the value for the full width at half maximum line profile width , I know the the density of the upper lasing state for the helium neon laser is 10^18 m−3, and I am assuming I have to use dN_2/dt = -A_21N_2, which I can turn into N_2(t)=N_2(t=0)exp(-A_21*t), and I have calculated the mean lifetime of the state to be t=1/A_21. I`m not too sure where i should go on from here, any advice would be appreciated, thanks.
I looked at the Füchbauer–Ladeberg formula, the Einstein Coefficients, the four level laser, etc, etc couldn't find an answer... interesting problem... maybe look into the details of the Helium Neon Laser. Not sure that Boltzmann is the right track- but could be wrong... this seems to be Post Graduate Level stuff... so there is perhaps a lack of foundational information... not surprised you haven't got any responses. Good luck- let us know if you come up with any interesting sources. Spontaneous decay (emission)(should perhaps be the same as absorption from Einstein)- 10^18 m-3 perhaps photonic density of lasing (or transparency??). ?
It seems this question slipped through the cracks and the OP is probably long gone. I think this one isn't so bad. I'd just like to clear it up for everyone else reading this thread.
There's a very skeletal discussion of the gain coefficient here. The gist of it is that the gain coefficient is defined as ##\gamma(\nu) = \frac{\partial I / \partial z}{I}## where ##I## is the intensity of the light in the gain medium and ##z## is the distance propagated. It also shows that ##\gamma(\nu) = n\frac{\lambda^2}{8\pi t_{sp}} g(\nu)## where ##\lambda## is the lasing wavelength (633nm for HeNe's), ##t_{sp}## is the spontaneous emission lifetime aka ##\frac{1}{A}## in terms of the spontaneous emission rate coefficient, and ##g(\nu)## is a unit-normalized Lorentzian lineshape representing the lasing transition. The unit-normalzied lineshape is given by $$g(\nu) = \frac{\Delta \nu / 2\pi}{(\nu - \nu_0)^2 + (\Delta \nu / 2)^2}$$, and if I'm not mistaking the notation of the linked pdf then ##\Delta \nu = \frac{A}{2\pi}##. So on resonance ##g(\nu_0) = \frac{1}{\pi} \times \frac{2}{A/2\pi} = \frac{4}{A}##. From this, it follows that $$\gamma(\nu_0) = 10^{18} m^{-3} \frac{(633*10^{-9}m)^2 * 3.39*10^7 s^{-1}}{8\pi} \frac{4}{3.39*10^7 s^{-1}} = 63772$$
I may very well have some rogue factors of ##2\pi## in there, but it gets the point across.
Likes rc1
Yes after commenting I realized the publish date. Thanks Twigg for the explanation. I couldn't follow the pdf- but your maths looks pretty fine- I'll have to look further at the background. Not sure how you slotted the transition probability into the equation- I'll have to review it again... Thanks Twigg.
The spontaneous emission rate coefficient ##A## comes in because it's related to the decay time. Since with no applied light the rate equation is $$\dot{N_e} = -A N_e$$ the population decays as $$N(t) = N(0) e^{-At}$$. In other words, the spontaneous emission decay time (##t_{sp}##), aka the time it takes for the population to decay to 1/e-th of it's initial level, is ##t_{sp} = \frac{1}{A}##.
Edit: sorry about the pdf being so poorly explained. It seemed like everything I found that discussed the gain coefficient was lecture slides. I think it's kind of a topic that no one really spends much time on. I've only heard "gain coefficient" used once or twice outside of class, after working on 20ish lasers in the time since. It's just an obscure term.
Likes rc1
Related to Finding the gain coefficient at line centre for a HeNe Laser
1. What is a gain coefficient?
A gain coefficient is a measure of the amplification of light that occurs within a laser medium. It is a unitless value that represents the increase in the intensity of light as it passes through the medium.
2. How is the gain coefficient calculated for a HeNe laser?
The gain coefficient for a HeNe laser is typically calculated by measuring the output power of the laser at different input powers and plotting a curve. The slope of this curve represents the gain coefficient at line centre.
3. Why is it important to find the gain coefficient for a HeNe laser?
The gain coefficient is an important parameter in determining the overall performance and efficiency of a laser. It is also a key factor in designing and optimizing laser systems for various applications.
4. What factors can affect the gain coefficient of a HeNe laser?
The gain coefficient of a HeNe laser can be affected by various factors such as the type and purity of the gas used in the laser medium, the temperature and pressure of the gas, and the alignment and stability of the laser cavity.
5. How can the gain coefficient be improved for a HeNe laser?
The gain coefficient of a HeNe laser can be improved by optimizing the laser cavity design, using high-quality gas with precise control of temperature and pressure, and ensuring proper alignment and stability of the laser components.
16K
  • Optics
