Finding the horizontal tan() lines of this equation
In summary, the conversation discusses finding the tangent line for a range of values instead of a singular value. The speaker suggests attempting a solution and showing work, and asks what would be done if the problem did not give a range of values. They also mention the condition for the tangent line to be horizontal and provide a helpful note.
user02103498
No Effort - Member warned that some effort must be shown
Find all points on the graph of the function f(x)=2sinx+sin(^2)x,0≤x<2π at which the tangent line is horizontal. Please list the x-values below separating them with commas.
2sinx+sin(^2)x
I've been able to find the tangent line with most equations, but I don't have any idea how to do it with a range of values instead of being given a singular value.
Hey, I think you're suppose to try to attempt a solution and show your work.
If the problem did not give you a range of values, then how would you try to solve this problem or what do you think you will see? Can you try a few of the first steps :)
Maybe a good starting point - can you describe what condition must be true for the tangent line to be horizontal?
It may help to note [tex]
2\sin x + \sin^2 x \equiv (1 + \sin x)^2 - 1.[/tex]
FAQ: Finding the horizontal tan() lines of this equation
What is the equation for horizontal tan() lines?
The equation for horizontal tan() lines is y = k, where k is any real number.
How do you find the horizontal tan() lines of a given equation?
To find the horizontal tan() lines of a given equation, set y = k and solve for x. The resulting values of x will be the points where the horizontal tan() lines intersect the given equation.
Can there be more than one horizontal tan() line for a given equation?
Yes, there can be multiple horizontal tan() lines for a given equation. This is because the value of k can vary, resulting in different horizontal tan() lines.
How do horizontal tan() lines affect the graph of an equation?
Horizontal tan() lines are parallel to the x-axis and do not intersect the graph of the equation. They can help determine the behavior of the graph and can also be used to find points of intersection with other lines or curves.
What is the significance of finding the horizontal tan() lines of an equation?
Finding the horizontal tan() lines of an equation can help identify key points on the graph, such as the x-intercept and the behavior of the graph at different points. It can also aid in solving problems involving the equation, such as finding points of intersection with other lines or curves.
