Finding the impulse response of a system
In summary, the problem asks to find the impulse response h(t) for a given equation. The first step is to substitute delta(t) for x(t), which simplifies the equation. However, solving the integral requires knowledge of the relationship for the Dirac delta function. After applying this relationship, h(t) can be solved in terms of t.
btse
So the problem asks to find the impulse response h(t) provided y(t) = integral from -infinity to t of e^-(t-tau)*x(tau-2)dtau
none
I understand that the way to begin this problem is to substitute delta(t) for x(t). Therefore the equation becomes y(t) = integral from -infinity to t of e^-(t-tau)*delta(tau-2)dtau
However, at this point I am unsure of how to begin solving the integral.
Thanks for any help.
The basic relationship for the Dirac delta function is
[tex]\int_{-\infty}^\infty f(x)\delta(x-x_0)\,dx = f(x_0)[/tex]
It picks out the value of the function f(x) when the argument of delta function is 0.
I understand the concept of the delta function. However, I am having trouble manipulating the integral. Each time I try something I achieve h(t) equal to a constant which is not correct at all. h(t) should be in terms of t.
Show your work. I have no idea how you are managing to get a constant.
To find the impulse response of a system, we need to first understand what an impulse response is. An impulse response is the output of a system when an impulse is applied as the input. An impulse is a very short signal with a very high amplitude and infinitesimal duration. In mathematical terms, an impulse is represented by the Dirac delta function, δ(t).
In this problem, we are given an input signal x(t) and the corresponding output signal y(t). The input signal is a function of time, and the output signal is the integral of the input signal over a certain time period. This means that the system is a linear time-invariant (LTI) system, where the output is the convolution of the input signal with the impulse response of the system.
To find the impulse response, we can use the definition of convolution, which is given by the integral of the product of the input signal and the impulse response over all possible time delays. In this case, the input signal is δ(t-2), which means that the impulse is applied at t=2. Therefore, the integral becomes:
h(t) = integral from -infinity to t of δ(t-2)*e^-(t-tau)dtau
To solve this integral, we can use the properties of the Dirac delta function, which states that δ(t-a) = 0 for all t ≠ a, and δ(t-a) = ∞ for t = a. This means that the integral will only contribute when t = 2, and the value of the integral will be 1. Therefore, the impulse response of the system is:
h(t) = e^-(t-2)
This is the impulse response of the system, and it can be used to find the output signal for any input signal using the convolution integral. I hope this helps in solving the problem.
Related to Finding the impulse response of a system
What is the impulse response of a system?
The impulse response of a system is a mathematical representation of how a system responds to an impulse, which is a short burst of energy. It is a function that describes the output of the system in relation to the input.
Why is it important to find the impulse response of a system?
Finding the impulse response of a system is important because it allows us to understand how the system behaves and how it responds to different inputs. This information is crucial in designing and analyzing systems in various fields such as signal processing, control systems, and communications.
How do you find the impulse response of a system?
The impulse response of a system can be found by applying an impulse input to the system and measuring the output. This can be done experimentally or mathematically using the system's transfer function.
What is the difference between an impulse response and a step response?
The impulse response and step response are both measurements of a system's behavior, but they represent different inputs. The impulse response is the system's output when an impulse input is applied, while the step response is the system's output when a step input (a constant value) is applied.
Can the impulse response of a system change over time?
Yes, the impulse response of a system can change over time if the system is dynamic or if the system parameters are altered. In these cases, the impulse response will vary depending on the input and the current state of the system.
