Finding the inside angle of a tetrahedron
In summary, the conversation discusses the structure of the methane molecule and the methods for finding the angle between the CH bonds. The first method involves finding the coordinates of the regular tetrahedron and using vector calculations. The second method involves assuming the carbon atom is at the origin and using the fact that the sum of all four vectors is zero. The dot product is used to find an equation involving the angle.
xaer04
38
"ASSIGNMENT 1
The Methane Molecule
Introduction: The methane molecule CH4, composed of four hydrogen atoms and one carbon atom, is shaped liked a regular tetrahedron. The four hydrogen atoms are on the vertices and the carbon atom is at the center. What is the angle between the CH bonds?
The fact that all the hydrogen atoms will behave the same allows us to make several simplifying assumptions. For example, all four of the inside angles HCH will be the same, so we only need to calculate one of them.
Your Task: Demonstrate how the angle can be found using both of the following methods. Give your answers in degrees and make sure it accurate to one place past the decimal. (If you get two different answers there is a good chance one of them is wrong!)
I. Find the coordinates of the regular tetrahedron, then use your knowledge of vectors to calculate the angle. Use a constructive method and show how you calculate the coordinates. For this part you may assume all the vectors have length one.
II. To get started for the second method, assume the coordinate system is chosen so that the carbon atom is at the origin. The four CH bonds can be viewed as four vectors. Notice the following facts:
a. All the vectors have the same length, since the bonds are identical.
b. The sum of all four vectors is zero. If this were not the case then there would be a net force and the atoms would be unstable.
To calculate the angle, start by writing an equation involving the four vectors. Next, in a fit of inspiration take the dot product of (both sides of) the equation with the one vector. Applying what you know about dot products, you will get an equation involving the angle . For this part you should complete the whole calculations without using the vector components for any step."
[tex]\vec{A} + \vec{B} + \vec{C} + \vec{D} = 0[/tex]
[tex]\vec{a}\cdot\vec{b} = \mid\vec{a}\mid\mid\vec{b}\mid \cos{\theta}[/tex]
I looked up the answer and it's supposed to be [itex]109.5^{\circ}[/itex], but i have no idea where to begin.
The picture is from wikipedia... I'm not too great at drawing in 3d.
Take the dot product of e.g. A with the vector equation. And start thinking about what the relations are between the parts.
Related to Finding the inside angle of a tetrahedron
1. How do you find the inside angle of a tetrahedron?
To find the inside angle of a tetrahedron, you can use the formula: (180 * (n-2)) / n, where n is the number of sides of the tetrahedron. For a regular tetrahedron, which has 4 sides, the inside angle would be 60 degrees.
2. What is the difference between an inside angle and an outside angle of a tetrahedron?
The inside angle of a tetrahedron is the angle formed by two adjacent sides on the inside of the shape. The outside angle is the angle formed by two adjacent sides on the outside of the shape. The sum of the inside and outside angles for each vertex of a tetrahedron is always 180 degrees.
3. Can you measure the inside angle of a tetrahedron with a protractor?
Yes, you can use a protractor to measure the inside angle of a tetrahedron. Place the protractor on one of the sides of the tetrahedron, making sure that the center point of the protractor lines up with the vertex of the angle. Then, read the angle measurement where the other side of the tetrahedron intersects with the protractor.
4. Why is the inside angle of a tetrahedron important?
The inside angle of a tetrahedron is important in geometry and 3D modeling as it helps determine the shape and dimensions of the tetrahedron. It is also used in calculations for various geometric properties of the shape, such as surface area and volume.
5. Are there any real-life applications of finding the inside angle of a tetrahedron?
Yes, the inside angle of a tetrahedron can be used in architecture and engineering for designing and constructing buildings and structures. It is also used in computer graphics for creating 3D models and animations. Additionally, understanding the inside angle of a tetrahedron is important in crystallography, a branch of science that studies the arrangement of atoms in crystals.
  • Classical Physics
