Finding the Integral using U-Substitution
  • Thread starter Broo4075
  • Tags
    Integral
In summary: So, In summary, by using the Integral Test and showing that the limit of e^u/u^4 as u goes to infinity is infinity, we can determine that the series ∑ ln(n)^-4 from n=2 to infinity diverges.
Broo4075
Use the Integral Test to determine convergence or divergence of the series:
Ʃ ln(n)^-4
n=2
Integral Test
d/dx ln(x)=1/x
f(x)=ln(x)^-4
I understand how to apply the Integral test. I just am having a difficult time finding the integral of f(x).
I tried using u-substitution, where u=ln(x)
du=(1/x) dx
dx=xdu
When I try to plug in the substitutions for u and du, I am left with the improper integral
∫x/u^4 du from 2 to Infinity
Since the x is still in there, I can't continue with the substitution.
Is there another way to go about solving the integral? Am I approaching the u-substitution wrong?
Ʃ ln(n)^-4
n=2
Integral Test
d/dx ln(x)=1/x
f(x)=ln(x)^-4
du=(1/x) dx
dx=xdu
You can get rid of the x. If u=ln(x) then x=e^u. But you still can't integrate it, really. And you don't have to. You just have to figure out whether it converges or diverges. What happens to your integrand as u->infinity? And for some minor technical points you really should say why you can apply the integral test in the first place, and for a second one of your limits on the u integral is wrong. x goes from 2 to infinity. What are the limits for u?
so as u increases, the integral equals zero?
I know I can use the integral test because f(x) is continuous, positive, and decreasing from 2 to infinity.
Good on justifying the use of the integral test. But my real point is that can you show that the limit of e^u/u^4 as u goes to infinity is infinity? Since the integral corresponds to area under the curve, the area under the curve must be infinity. So the integral will diverge. Even if you can't write an antiderivative for e^u/u^4, you will still know that.
oh okay, I see now. And since the Integral diverges, the series also diverges. Thank you so much. That helps explain quite a few problems that I have, but now they make sense
FAQ: Finding the Integral using U-Substitution
What is U-Substitution?
U-Substitution is a method used in calculus to find the integral of a function by substituting a new variable, u, for a part of the original function. This allows for the integral to be solved in a simpler form.
When should I use U-Substitution?
U-Substitution is useful when the integrand (the function being integrated) contains a single term that is not a variable, such as a polynomial, exponential, or trigonometric function. It is also helpful when the integral has a complicated or nested structure.
How do I perform U-Substitution?
To perform U-Substitution, follow these steps:
1. Identify the part of the function that can be substituted with u.
2. Let u be equal to this part of the function.
3. Use the chain rule to express the remaining part of the function in terms of u.
4. Rewrite the integral in terms of u, replacing the original part of the function with u.
5. Solve the integral in terms of u.
6. Finally, substitute back in u in terms of the original variable to get the final answer.
What is the purpose of using U-Substitution?
The purpose of using U-Substitution is to simplify the integral and make it easier to solve. By substituting a more manageable variable, the integral can often be solved using basic integration techniques, such as the power rule or integration by parts.
Are there any limitations to using U-Substitution?
Yes, there are some limitations to using U-Substitution. This method is not applicable to all integrals and may not always result in a simpler integral. Additionally, it may be challenging to identify the correct substitution to use, and the process can be time-consuming.
