Finding the intergral function (dy/dt = a(q-y))
  • Thread starter miniradman
  • Tags
    Function
In summary: I'm not sure if that will work or not.That sounds like a good plan. Try differentiating each function by itself and then combining them. That seems like a good way to go about it.
  • #36
Well, we've learned the u substitution, but we've never applied it to a question like this.
But I must queery, why don't we use the u substitution method for Newton's law of cooling questions?
[itex]\frac {dT}{dt} = k (T - T_s)[/itex]
  • #37
From what I'm seeing, I think you would use u substitution (in one of the simplest cases possible with u = T - T_s; du = dT) after you separate the variables and integrate both sides.
  • #38
That's the thing... I never differentiate u (or T - T_s)?
Considering that the question I posted is almost (but not exactly) the same as the rule for Newton's Law of Cooling. Hence the reason why I went straight from
[itex]\normalsize\int\frac {dy}{(q-y)} [/itex]
to
[itex] ln |q-y| [/itex]
because I've done many Newtons law of cooling questions, none of which did I differentiate "u" (in fact, I didn't even use u)
  • #39
to
I'm a bit unsure what you're asking. At the least, do you see how to do
[tex]\int \frac{dT}{T-T_s}[/tex]
using u substitution? It's likely you never used u substitution to do it, because it's so basic that you can just think out what the answer is. But if you ever get stuck, you can rely on the systematic application of certain tools they teach you like u substitution.
  • #40
oh, well I just tried doing it with the du = d(whatever) method and I found that du = dT. Which means that I didn't have to adjust the formula at all... it all makes sense now.
  • #41
Yeah. You just get
[tex]\int \frac{du}{u}[/tex]
That's what makes it probably the simplest (yet still useful) u substitution possible. The simplest is to let u = x.
  • #42
We can infer from what you said that the substitution u = x is not useful, which is true. Using the substitution is not useful, because all you would be doing is changing a letter in the problem.
  • #43
Hi.
miniradman said:
So then shouldn't the final function be ?
[itex]y = -Ae^{-at} + q[/itex]
Back to your first post
miniradman said:
Find the intergral function of:
dy/dt=a(q-y) where t ≥0, y(0)=0 a and q are constants.
So A=q then y = q(1-e^-at). If y is temperature of a body for example, from zero it is warmed up to the temperature of heat bath q. Regards.
  • #44
Hmmm, I've completely forgotten about that condition... it all makes sense now!
Thanks again sweet springs! :smile:
