MHB Finding the intersection points on the graph y=sinx, y=cosx and y=tanx
The discussion focuses on finding the intersection points of the trigonometric functions y=sinx, y=cosx, and y=tanx within the interval [0, π/2]. The user successfully identified the intersection point of y=sinx and y=cosx as (π/4, √2/2) and confirmed that y=sinx and y=tanx intersect at (0, 0). They initially struggled with finding the intersection points for y=cosx and y=tanx but eventually used the quadratic formula to determine valid intersection points in the first quadrant. The thread highlights the importance of algebraic manipulation and identities in solving trigonometric equations. Overall, the user expressed gratitude for the assistance received in solving their math problems.
Alexander1
Hi guys, I'm new to this site and it seems like it will be a great resource when I'm stuck on a problem. I'll firstly set out the question and then add in my working so far.
Question: I was firstly asked to graph the trigonometric functions y=sinx, y=cosx and y=tanx in the interval where x is greater than or equal to 0 but less than or equal to pi/2. My question is to find algebraically the points of intersection of the three curves in that interval. So far I have found the intersection points for where y=cosx and y=sinx cross (hopefully I'm right - I got root 2/2 for both coordinates).
I'm now struggling with finding the intersection points for where y=cosx and y=tanx cross as well as the points for where y=sinx and y=tanx cross.
I know that the points for y=sinx and y=tanx will be (0,0) as it can easily be see from the graph. This is my working so far for that...
1. y=sinx
2. y=tanx
Sub 1. into 2.
sinx=tanx
Using the identity:
tanx=sinx/cosx
(I'm not too sure here if I'm meant to be finding an angle?)
sinθ=sinθ/cosθ
cosθ x sinθ = sinθ
cosθ=1
θ=cos-1 (1)
θ=0
I'm not really sure where to go from here to show that it must have an intersection point of (0,0) - It would be greatly appreciated if someone could please help me on this.
Lastly, I'm also not sure how to find the intersection points for where y=cosx and y=tanx cross.
For this I really haven't got much at all. I do know that I must use the identity sin2 x + cos2 x = 1 (I'm pretty sure). At the moment this is all I have...
1. y=cosx
2. y=tanx
sub 1. into 2.
cosx=tanx
cosx=sinx/cosx
cosx x cosx = sinx
(This step below may be wrong?)
cos2x=sinx
Using the identity sin2 x + cos2 x = 1
cos2 x=1-sin2 x
From here I'm stuck on how to find the intersection points?
If anyone could help me find these intersection points for the 2 questions above I would be very grateful. Sorry about the lengthy thread.
Thanks in advance!
Mathematics news on Phys.org
Hello bersim! Welcome to MHB!
Yes, you're right, $\sin x=\cos x$ yields the intersection point $\left(\dfrac{\pi}{4},\,\dfrac{\sqrt{2}}{2}\right)$.
1. y=sinx
2. y=tanx
Sub 1. into 2.
sinx=tanx
Using the identity:
tanx=sinx/cosx
Yes, in solving for any trigonometric functions, we are actually dealing with the angles and so, our $x$ is angle measured in radians.
bersim said:
sinθ=sinθ/cosθ
cosθ x sinθ = sinθ
cosθ=1
θ=cos-1 (1)
θ=0
Here, I see that you divided the equation $\cos x \sin x= \sin x$ by $\sin x$. You could do that if $\sin x\ne 0$ because we can never divide any number by zero, as division by zero is undefined.
So, what we could do is, we move $\sin x$ to the left side, and then we factor the LHS expression.
$\cos x \sin x- \sin x=0$
$\sin x(\cos x-1) =0$
When we have a product equals zero, then either one of them or two of them is zero.
We hence set $\sin x=0\implies x=0$ on the given interval and $\cos x-1=0\implies x=0$ and so, when $x=0$, $y=\sin x=\sin 0=0$ and the only intersection point between the graph $y=\sin x$ and $y=\tan x$ on the given interval is $(0,\,0)$.
1. y=cosx
2. y=tanx
sub 1. into 2.
cosx=tanx
cosx=sinx/cosx
cosx x cosx = sinx
cos2x=sinx
cos2 x=1-sin2 x
What you need to do now is to replace $\cos^2 x=1-\sin^2 x$ into the equation $\cos^2 x=\sin x$ and solve for $\sin x$.
Can you show me how you would do in this last part of the problem?
Hi Anemone, thanks very much for your help. I actually managed to find all of the intersection points after a bit of thinking. For the y=cosx and y=tanx one I used the quadratic formula and then found the 2 x intercepts, although only one is valid due to it being in the 1st quadrant. I then subbed x into y=cosx (although it works with both) and found my y coordinate.
Cheers, Jack
I am happy that you solved the problem! I welcome you to ask(post) again when there is something in math that puzzles you.
I'll definitely make sure I use this again when I'm having trouble! It seems so obvious now haha.
Thanks
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
