Finding the largest angle from the central maximum (single slit diffraction)
In summary: This is a multiple-choice question, so there are 4 possible answers. The correct answer is A.) 3.B.) 4.C.) 5.D.) 6.3.
HenryHH
A single slit, 1400 nm wide, forms a diffraction pattern when illuminated by monochromatic light of 490 nm wavelength. The largest angle from the central maximum at which the intensity is zero is closest to:
A) 44° B) 38° C) 35°
d = 1400 nm, lambda = 490 nm.
sin(theta) = wavelength/d
Plugging in variables, I have sin(theta) = 490/1400 = .35. To get theta, I multiplied .35 by sin inverse (sin^-1). I keep getting approximately 20 degrees, but the correct answer is A.) 44 degrees. I don't understand what I'm doing wrong, unless there's some extra step I should be doing... ?
You have found the first minimum, or the one closest to the central maximum. You are being asked to find the minimum farthest from the central maximum.
Thanks. Will I need to use a different formula since I don't have any other variables?
No, it is the same formula:
[itex]a \text{sin}(\theta_n) = n \lambda[/itex]
It is just more generalized, along you to find the nth minimum.
Thanks. This is probably a dumb question, but how would I figure out what to plug-in for n? I now know that I am finding the minimum farthest from the central maximum, but I don't know what number would correspond with that, if that statement makes any sense.
You will have to do this by trial and error. Figure out what the maximum meaningful diffraction angle is in a single slit experiment, and then find the biggest value of [itex]n[/itex] that results in an angle less than that maximum angle.
I'm kind of confused... when you say trial and error, will I just be plugging in random numbers for n? Also, just to be sure, is a in the formula you posted the same as d (the slit width)?
My confusion with doing it the trial and error way deals with the fact that I won't know when I've gotten the correct answer. The correct answer is 44 degrees, but I don't know how they determined that 44 degrees was the largest angle versus any other angle...
Yes, they are the same.
If you use [itex] n = 3[/itex], you get [itex]\text{sin}(\theta) = 1.05[/itex]. Is there any angle [itex]\theta[/itex] such that that can be true? The same argument holds for all [itex]n > 2.[/itex]
So basically, I'm just plugging in 1,2,3... for n until I get the biggest number for theta that also happens to be an answer choice? In other words, this particular problem wouldn't be solvable if it wasn't a multiple-choice question?
The general way to solve this is to recognise that the largest angle is 90 degrees so this largest value of Sin∅ is 1
This gives the max value of n to be a/λ which must be rounded down tot find the number of minima
FAQ: Finding the largest angle from the central maximum (single slit diffraction)
What is the central maximum in single slit diffraction?
The central maximum is the brightest spot in a diffraction pattern created by light passing through a single slit. It occurs directly in front of the slit and is the result of constructive interference of light waves passing through the slit.
How is the largest angle from the central maximum determined?
The largest angle from the central maximum can be determined by measuring the distance from the central maximum to the first minimum on either side of the central peak. This distance is known as the angular width of the central maximum and is used to calculate the angle using the formula theta = lambda / b, where lambda is the wavelength of light and b is the width of the slit.
What factors affect the size of the central maximum angle?
The size of the central maximum angle is affected by the wavelength of light, the width of the slit, and the distance between the slit and the screen. Longer wavelengths and wider slits result in larger angles, while shorter wavelengths and narrower slits result in smaller angles. Increasing the distance between the slit and the screen also decreases the size of the angle.
How does the central maximum angle change with different types of light sources?
The central maximum angle is directly proportional to the wavelength of light. This means that different types of light sources, such as red, green, and blue light, will result in different central maximum angles since they have different wavelengths. The angle will also change with different types of light sources that emit multiple wavelengths, such as white light, as the central maximum will be a combination of all the wavelengths present.
How is the central maximum angle used in real-world applications?
The central maximum angle is used in various applications, such as in the field of optics. It is used to determine the resolution of optical instruments, such as microscopes and telescopes, by measuring the size of the central maximum and the distance between the central maximum and the first minimum. It is also used in the study of diffraction patterns and can provide information about the properties of light and the structure of matter.
