Finding the limit? Piece function, stuck.
In summary, the problem is that you are not sure what to do when x does not equal 1 on the graph, but the limit says x->1. You should use the definition of limit given to you in class.
NapoleonDM
Hi,
I don't know what to do, and am stuck on this question.
Let f(x) =
{x^2+4, x does not equal 1
(left?)
{1, x=1 (right?)
Lim F(x)
x->1
First it gives a graph.
A parabola but at x=1, y=5, there is an open dot, (hole in the graph) so it cannot equal 5?
and then there is the random black dot at x=1, y=1.
ok so I follow the graph from the left and the right and I get 5, but there is a hole there, and a random black dot on the graph not part of the parabola.
as x approaches 1, y approaches...? (I want to say 5, but there's that darn hole!)
But I am confused bc of the left part "x^2+4, x does not equal 1"
What do I do when it "doesn't equal 1" but the limit says x->1?
If it says lim x->1, yet CAN'T be 1 for the left side, then what do I do?!
So can someone explain this problem? Is it just "does not exist"?
NapoleonDM said:
Hi,
Let f(x) =
(left?)
{1, x=1 (right?)
Lim F(x)
x->1
and then there is the random black dot at x=1, y=1. so I follow the graph from the left and the right and I get 5, but there is a hole there, and a random black dot on the graph not part of the parabola.
No, this limit very definitely exists and is simple.
Do you remember the definition of "limit":
[itex]\lim_{x\rightarrow a} f(x)= L[/itex] if and only if, for any [itex]\epsilon> 0[/itex], there exist [itex]\delta> 0[/itex] such that if [itex]0< |x-a|< \delta[/itex] then [itex]|f(x)- L|< \epsilon[/itex].
In particular, look at that "0< |x- a|". The value of f at x= a, or even whether f(a) is defined is irrelevant!
The function must be close to the limit for x close to but not equal to a. Now, suppose x is very very close to 1 but not equal to 1. What is f(x) close to?
It looks like it is getting "closer" to 5.
I learned that definition 1 week ago. These holes and graphs have made me so confused... esp in other sections we just learned, when you have the "removable discontinuity." We only use that if we have a fraction and it makes the denominator equal to zero (after we simplify), right?
I'm confusing the sections in the book with each other.
But for this problem, should I use lim x->1.001, and lim x->0.999? or the definition you gave me for limit(we've used that for proofs)?
I'm just not sure when to use what method always.
There's another problem like it asking for the limit, but it's rational, and the directions are the near the same for each, so now I'm a little confused.
But I have only been in class 2 weeks, so I will keep reviewing and hope it will embed itself in my brain soon.
No, that happens any time you have a point at which the limit exists but is not equal to the value of the function there.
For example: f(x)= 3x if x is not 1, 10000 if x= 1. Obviously (I hope it's obvious!) the limit of that function, as x goes to 1, is 3. Since f(1)= 10000, not 3, the function is not continuous there. But we can "remove" that discontinuity just by redefining f(1) to be 3. (Of course, then f(x) is the simple f(x)= 3x.)
Why in the world would you use "lim x-> 1.001" and "lim x-> 0.999" when you were told to use "lim x-> 1"? My point was that you can ignore what happens at 1 but what happens arbitrarily close to 1 (1.0000000000000000000001 and even closer!) is important.
Oh. I used it bc I was looking through my class notes, and that's what the professor did.
But I guess he was showing us they both were getting closer to the same number (from the left and from the right...).
FAQ: Finding the limit? Piece function, stuck.
What is a limit in mathematics?
A limit in mathematics is a fundamental concept that describes the behavior of a function as the input approaches a certain value. It is used to determine the value that a function approaches as the input gets closer and closer to a specific point.
How do you find the limit of a function?
To find the limit of a function, you can use various techniques such as direct substitution, factoring, and applying algebraic rules. Additionally, you can use graphical methods, numerical methods, or the formal definition of a limit to find the limit of a function.
What is a piecewise function?
A piecewise function is a function that is defined by multiple sub-functions, each of which applies to a certain interval of the function's domain. It is often used to represent functions that have different behaviors or rules in different parts of the domain.
How do you evaluate a piecewise function?
To evaluate a piecewise function, you need to determine which sub-function applies to the given input value. Then, plug in the input value into the corresponding sub-function and solve for the output. Repeat this process if the input value falls into another interval of the function's domain.
What should I do if I get stuck while finding the limit?
If you get stuck while finding the limit, you can try using different techniques or methods to approach the problem. You can also seek help from a math tutor or classmate, or consult online resources for step-by-step solutions. It is also helpful to review the basics of limits and functions to better understand the problem.
