Finding the magnitude of a couple
In summary, the problem involves a 140-lb uniform steel plate welded to a shaft and maintained in position by a couple M. The shaft is prevented from sliding by collars and lies in the yz plane. The goal is to plot the magnitude of the couple M as a function of θ for 0<= θ<=90. The solution involves finding the equation of sum of M along the axis EF and setting it equal to 0. A diagram is provided for reference.
Heat
273
The 140-lb uniform steel plate ABCD is welded to shaft EF and is maintained in the position shown by the couple M. Knowing that collars prevent the shaft from sliding in the bearings and that the shaft lies in the yz plane, plot the magnitude M of the couple as a function of θ for 0<= θ<=90.
http://img378.imageshack.us/my.php?image=figurefz3.jpg"
2. The attempt at a solution
From what I understand, this problem requires a system equivalent to zero.
Sum of F = 0
Sum of M (along EF) = 0
I am having problems setting/getting started on this problem. :confused:
What is [tex]\theta[/tex]? A diagram might be useful.
I uploaded the pic, just click on the word 'diagram'. :)
Heat, do you understand why they are giving you the weight of the plate? and yes you need to find the equation of sum of M along the axis EF and equal it to 0.
Start by setting the equation.
Related to Finding the magnitude of a couple
What is a couple and how is it different from a force?
A couple is a pair of forces that are equal in magnitude, opposite in direction, and act on different points of an object. Unlike a single force, which can cause linear motion, a couple creates rotational motion.
How is the magnitude of a couple measured?
The magnitude of a couple is measured by the product of one of the forces and the perpendicular distance between the forces. This distance is known as the moment arm or lever arm.
What is the formula for finding the magnitude of a couple?
The formula for finding the magnitude of a couple is M = F x d, where M is the magnitude of the couple, F is the force applied, and d is the distance between the forces.
Can the direction of a couple be changed?
Yes, the direction of a couple can be changed by reversing the direction of one of the forces while keeping the other force unchanged. This will result in a change in the direction of the rotational motion.
What are some real-life examples of a couple?
Some real-life examples of a couple include opening a door, tightening a bolt with a wrench, and twisting a bottle cap. In each of these situations, a pair of forces are applied in opposite directions, causing rotational motion.
11K
