Finding the Mass of a 1m Measuring Stick Balancing a 2kg Rock
In summary, a 2kg rock is suspended by a massless string from one end of a 1m measuring stick. The mass of the measuring stick is 2kg if it is balanced.
Lo.Lee.Ta.
217
"A 2kg rock is suspended by a massless string from one end of a 1m measuring stick."
1. "A 2kg rock is suspended by a massless string from one end of a 1m measuring stick. What is the mass of the measuring stick if it is balanced as shown below."
______________
|___|___|___|___|
M...^
Okay, this is not a very good drawing of the situation... But I am trying to show a meter stick on a fulcrum (^) and the 2kg mass is the M.
So the M is at the very end, at the 0m mark.
The fulcrum is at the .25m mark.
I need to figure out the mass of the meter stick...
2. I didn't really know there was a formula to working these sorts of problems at first, so I just though a reasonable answer would be 4 kg... 3kg on each side of the fulcrum is balanced...?
But this is not right... The answer is 2kg for the meter stick.
How am I supposed to figure this out?
I know the formula for the center of mass is: [x1(m1) + x2(m2) +...]/(m1 + m2 +...)
But I don't think this formula will help me because the "balance beam" is not massless.
Please help me to figure this out! :/
Thank you! :)
Oh, wait a second!
I just went on one website after researching this problem forever, and MAY have found the answer...
Is this right?
In (m1)(x1) + (m2)(x2) +.../(m1) + (m2)...,
The m's stand for the distance away from the fulcrum?
And we always say the middle of the beam is where the mass of the beam is located?
That's why we put the weight of the beam at m2?
*f stands for fulcrum
m1--f---m2--m3--m4
|___|___|___|___|
M...^
So it's:
(m2)(x2) + (m3)(x3) + (m4)(x4) = (m1)(x1)
(.25m)(weight of beam) + (.5)(0) + (.75)(0) = (2)(.25)
So weight of beam = 2kg
Is this how it is solved?
Lo.Lee.Ta. said:
m1--f---m2--m3--m4
|___|___|___|___|
M...^
So it's:
It's not clear to me what those equations are saying or how you arrive at them.
Is it one equation or two? If two, the first seems wrong.
Look like you're breaking the mass of the beam into four equal sections, but for the distance to the mass centre of each section you've written the distance to the far point of the section.
FAQ: Finding the Mass of a 1m Measuring Stick Balancing a 2kg Rock
1. How do you determine the mass of a 1m measuring stick?
The mass of a 1m measuring stick can be determined by using a balance or scale to measure its weight in either kilograms or grams.
2. What is the purpose of balancing a 2kg rock on the measuring stick?
The purpose of balancing a 2kg rock on the measuring stick is to provide a known weight to use in the calculation of the measuring stick's mass.
3. Why is it important to use a known weight when finding the mass of the measuring stick?
Using a known weight, such as the 2kg rock, provides a reference point for the measurement and ensures accuracy in determining the measuring stick's mass.
4. Can you find the mass of the measuring stick without balancing a weight on it?
Yes, the mass of the measuring stick can also be determined by using other methods such as calculating the density of the material it is made of or measuring its displacement in water.
5. Is it necessary for the measuring stick and rock to be perfectly balanced for an accurate measurement?
No, it is not necessary for the measuring stick and rock to be perfectly balanced. As long as the measuring stick is stable and not tilting to one side, an accurate measurement can still be obtained.
20K
42K
9K
