How Can You Calculate Saturn's Mass Using a Telescope and Stopwatch?
In summary, the question is whether it is possible to use a telescope and stopwatch to find the mass of Saturn, and if so, what approach should be taken? One possible approach is to use Kepler's laws and the orbital period of Saturn's moons to calculate the range between Saturn and its moons, and then use the formula M = 4π^2 r^3/GT^2 to find the mass of Saturn. However, this approach requires knowledge of the speed of light, which may not be obtainable with the given tools. Another approach is to use astronomical observations to estimate the distance between the Sun and Saturn, and then use this as a reference to calculate the range between Saturn and its moons. Ultimately, without knowledge of Saturn's
Abu
Using only a telescope and a stopwatch, find the mass of Saturn.[/B]
(This question may or may not make any sense at all, it was a theoretical lab that my professor said without giving us a chance to copy it down and I am trying to recall the question from memory)
If it is impossible then let me know, I am taking a chance because this may be a very dumb question haha.
T^2/R^3 = T^2/R^3
v = 2πr/τ
d = vt
v = √GM/R
M = 4π^2 r^3/GT^2
3. The Attempt at a Solution
At first, I thought that:
If it is possible to find the orbital period of Saturn around the sun using a telescope and stopwatch along with an extreme amount of patience, then you could simply use Kepler's 3rd law with Earth's known values to find the range between the sun and Saturn. Then you could use this range in the formula M = 4π^2 r^3/GT^2, but then I realized that M would be the mass of the Sun and not of Saturn.
So then I thought if it is possible to apply the M = 4π^2 r^3/GT^2 formula between Saturn and one of its many moons. Then, M would be the mass of Saturn, r would be the distance between the moon and Saturn, and T would be how long it takes for a moon to revolve around Saturn, using the stop watch and patience.
The only problem is R, which you need the speed of light for. Is it possible to somehow calculate the speed of light with only what was given, and then apply it to find the range, and if so, how? If it isn't possible, then I assume my professor would just simply give the speed of light?
Please explain your thinking there.
I thought that you need the speed of light first so that you can use the formula:
v = d*t where v is the speed of light, d is the distance between the moon and Saturn, and t is the time it takes for the speed of light to cover that distance. Then you would use d in the formula mentioned.
As I am typing this out though, that hardly makes any sense because even if I did know the speed of light, I wouldn't know the time it takes for the speed of light to cover that distance. Does that mean it is impossible with what is given? It seems to me like either way there will be difficulties.
I just realized now that keplers laws could also apply to the moons revolving around saturn. Do you think i could use that, in theory? But then range would be a problem again, right. Or is there something else I am missing.
You can see the moons revolving around Saturn. What parameter do you need to figure out from that how far apart they are?
The only other parameter i could think of that would help in solving the range of the moon from Saturn is the radius of Saturn, because the total range is how far the moon is from the surface plus the radius. Sorry if it is super obvious, I am just confused.
It's difficult obtain the mass with just a stopwatch and a telescope.
In Newtons time, people could predict planetary motions but they didnt really know the distance between the Earth and the Sun. And they also didnt know the masses of these objects. To obtain it, you need a local measurement of the gravitational constant G and the surface gravity g of the Earth. Then the other stuff follows.
Without knowledge of Saturns "surface" gravity or the distance to Saturn you can't get it's mass. A speed of light approach may work, assuming you already know the speed of light and the distance from the Earth to the Sun. But then, if you know the latter you can already pretty much calculate the distance to Saturn and the distance between Saturn and its moons from astronomical observations alone.
Alright, so if I were to use the speed of light approach, how would I go about it? I know that you need to use the distance equals speed multiplied by time formula for that but time would be an issue. Would you somehow need to reflect something to see how fast the light travels from Saturn, as ridiculous as that sounds, to see the distance between Earth and Saturn? I feel like I am on the wrong track... by astronomical observations you mean using the distance between the Sun and Saturn as a reference to base an estimate for the range of the moon to Saturn?
What I think you should do is this: Assume you know the mass of the Sun. Then you also know the distance between the Sun and, let's say, Mars, from it's orbital period. From that point you should be able to derive the distance between Saturn and one of its moons by comparing it to the distance between Saturn and Mars. (The geometry may be a bit complicated but it's clearly doable)
If you see a vertical pole in the distance, what do you need to know to figure out how tall it is?
Related to How Can You Calculate Saturn's Mass Using a Telescope and Stopwatch?
What is the mass of Saturn?
The mass of Saturn is approximately 5.683 x 10^26 kilograms.
How was the mass of Saturn calculated?
The mass of Saturn was calculated by using Kepler's Third Law, which relates the orbital period of a planet to its distance from the Sun and the mass of the Sun. By observing the orbital period and distance of Saturn, scientists were able to determine its mass.
Why is it important to know the mass of Saturn?
Knowing the mass of Saturn is important for understanding the overall mass and composition of our solar system. It also helps scientists to better understand the formation and evolution of Saturn and its moons.
Has the mass of Saturn changed over time?
The mass of Saturn has not significantly changed over time. However, small variations in its mass may occur due to impacts from comets or other objects.
How does the mass of Saturn compare to other planets?
The mass of Saturn is the second largest in our solar system, after Jupiter. It is more than 95 times the mass of Earth and about one-third the mass of Jupiter.
  • Classical Physics
