Finding the max angle of a longboard deck before the wheels slip
In summary, the conversation was about calculating the maximum angle that an electric longboard can be tilted before the wheels slip on the road based on speed. The process involved finding the correlation between the radius of the curve and the angle of the wheels, as well as calculating the centrifugal force and friction force. However, there were issues with the results not making sense and potential errors in the calculations. The conversation also discussed the concept of crowned wheels and the coefficient of friction, and how these factors can affect the maximum tilt angle. It was suggested to measure acceleration directly instead of relying on calculations for a more accurate result.
CK_KoopaTroopa
Hi, I'm making an electric longboard and trying to write an app for my phone to function as the remote. I've got a bunch of fancy Star-Trek-esque indicators on it, one of which is the pitch and roll of the deck. All the indicators have "danger zones" and turn red when they hit them, and for this the danger zone will be dynamic as your speed changes so I'm trying to find the maximum angle (roll) in degrees that the board can be tilted to turn before the wheels slip on the road based on speed. I thought I had it down, but must have done something wrong because the results don't quite make sense so here's my process (sorry for the picture being so scatter-brained haha)
So, the board turns in a circle whose radius r changes as some function of the roll, θr. More directly, the radius depends on the angle of the wheels with the midline of the deck, θw (see lower right section of picture for clarification). One can calculate this correlation based on the length between the trucks, lw by using SOH (sin = opposite/adjacent) to get
sinθw = lw / 2r ⇒ r = lw/2sinθw
To get θw as a function of θr, I figured out it's a sinusoidal relationship to the baseplate angle θb, specifically
θw = θbsinθr
Therefore, the radius of the curve is
r = lw / 2sin(θbsinθr).
Now, to get the centrifugal force, the formula is mv2 / r, so we can simply plug in what we got for r to get
Fcen = mv2 / (lw / 2sin(θbsinθr))
which can simplify to
Fcen = 2mv2sin(θbsinθr) / lw
The force that has to counteract that is the force of friction between the wheels and the road (with axis of movement parallel to wheel's axis of rotation), the maximum of which is Ffric = μmg. Therefore to figure out the maximum θr (the end goal of all this), we need to
solve Ffric = Fcen for θr
Oh boy, here we go.
μmg = 2mv2sin(θbsinθr) / lw
First of all, the m's cancel out, meaning it's apparently mass independent (makes sense; a heavier person will produce more centrifugal force but also push harder on the ground increasing friction), so now let's just algebra the crap outta this:
μglw = 2v2sin(θbsinθr)
μglw / 2v2 = sin(θbsinθr)
sin-1glw / 2v2) = θbsinθr
sin-1glw / 2v2) / θb = sinθr
sin-1(sin-1glw / 2v2) / θb) = θr
Therefore,
θrMax = sin-1(sin-1glw / 2v2) / θb)
This should be the end of the problem, but when I applied it to the program and plugged in appropriate values for all the variables, it wasn't behaving properly (for example, when the coefficient of friction is set to 1 the maximum roll should be 90 regardless of speed but it still changes as the speed changes). Any ideas on what I might've done wrong? Do I need to bring calculus into this somewhere as an optimization problem? I'm at a loss...
Likes berkeman
Are the wheels "crowned?" Any cylinder/roller/wheel with a non-zero width is going to be slipping all the time in a turn.
I don't think they're crowned if I understand that term correctly... I haven't actually purchased or built anything yet, I'm just getting the software down first and will put in values later. I realize that the wheels are slipping during a turn due to the geometry of how it works and therefore the curve itself can't be perfectly measured with this method, but I'm only trying to calculate the point at which it will cross from that required direct slippage into centrifugal force induced skidding. Maybe I am going about this entirely the wrong way though... Is there a better approach...?
Why?
A.T. said:
Why?
Might be missing something here, but if the coefficient of friction is 1, doesn't that mean the surfaces have infinite friction between them (cannot move no matter how much force is applied)? And if that's the case, the maximum amount you could tilt the board to steer should be the maximum amount possible in its range of motion, which theoretically is 90°. In practice it would be less than that due to collisions, but mathematically speaking the maximum roll relative to exactly flat is exactly sideways.
No.
Ok... Care to elaborate? What DOES a coefficient of 1 mean?
Why don't you look at your own post:
... maximum of which is Ffric = μmg ...
What does μ = 1 imply?
Ohhhkay. I'm not sure what algorithm I was confusing with this but that makes more sense. Also, having thought about this for a couple days I'm realizing that it wouldn't work anyway, because it doesn't account for tilted roadways etc. Better to measure acceleration of the board directly which would be more reliable anyway since I can directly compare that with μmg.
As for the constant wheel slippage during a turn, maybe I could do some research and measurements and come up with a formula for a dynamic coefficient of friction for the wheels based on speed and maybe vibration, which would be more accurate.
Likes Tom.G
Related to Finding the max angle of a longboard deck before the wheels slip
1. What is the purpose of finding the max angle of a longboard deck before the wheels slip?
The purpose of finding the max angle of a longboard deck before the wheels slip is to determine the maximum angle at which the longboard can safely turn without the wheels losing traction and slipping. This can help riders determine the limits of their longboard and avoid potential accidents.
2. How is the max angle of a longboard deck before the wheels slip calculated?
The max angle of a longboard deck before the wheels slip is calculated by using the coefficient of friction between the wheels and the ground, as well as the weight distribution and speed of the rider. It can also be affected by factors such as the type and condition of the wheels and the surface of the ground.
3. What factors can affect the max angle of a longboard deck before the wheels slip?
Factors that can affect the max angle of a longboard deck before the wheels slip include the coefficient of friction between the wheels and the ground, weight distribution and speed of the rider, type and condition of the wheels, and surface of the ground. Other factors such as weather conditions and rider technique can also play a role.
4. Why is it important to know the max angle of a longboard deck before the wheels slip?
Knowing the max angle of a longboard deck before the wheels slip is important for the safety of the rider. It allows them to understand the limits of their longboard and avoid potential accidents. It also helps riders choose the appropriate speed and angle for turning, enhancing their overall riding experience.
5. Can the max angle of a longboard deck before the wheels slip be increased?
Theoretically, yes, the max angle of a longboard deck before the wheels slip can be increased by adjusting factors such as the weight distribution, type and condition of the wheels, and surface of the ground. However, it is important to note that increasing this angle can also increase the risk of accidents. It is important for riders to always prioritize safety and ride within their skill level and the limits of their longboard.
22K
9K
