Finding the max/min values of this function?
  • Thread starter Vitani11
  • Tags
    Function
In summary, the function f(x) = [(x2-7x+12)/(x-1)]e-x/2 has three real roots, one of which is close to x = 0, and no asymptotes. The local maxima and minima can be approximated by finding the points where the derivative of the function is equal to zero.
Vitani11
275
Analyze the function f(x) = [(x2-7x+12)/(x-1)]e-x/2. Identify the zeroes, local maxima, and minima (approximate locations), as well as points where the function "blows up", give asymptotic values (for x→±∞), and sketch the function.
f'(x) = (e-x/2(12-7x+x2)+(-1+x)[e-x/2(-7+2x)-((e-x/2)/2)(12-7x+x2)))
Above is the derivative. I can't just solve this thing for x, can I? It's hellish and involves logs and there is a high chance that I'll mess up. However the professor said approximate. So how do I do that? I was never formally taught how to approximate a functions local max or min. Do I binomial expand each term in the derivative after simplification of it and then find the zeros?
What about the asymptotes? Can't just do long division to find it because there is an e-x/2 in there...
By asymptotes, I think they mean for you to find places where f is undefined. Think about where the denominator is zero.
For f', combine the fractions you get into a single fraction, all multiplied by e-x/2. Since e-x/2 is never zero, see if you can at least approximate where the numerator of the fraction is zero.
You can look for zeros exactly, and you can identify where the function "blows up", and how the function looks for very large and very small x. Combine that to make a sketch of the function. You can also use a computer (e.g. calculate the value of the function for various values of x).
The derivative looks wrong, and it won't help much. Edit: Turns out the correct derivative does help.
The derivative is all of that over (x-1)2. Sorry there was so much in it to write that I forgot a portion of it. I know this is correct now because of Wolfram Alpha. The zeroes I have no problem with. I have to do all of the things listed though, I can't just sketch the function using other means unfortunately. How do I go about finding the max and mins? What approximation technique should be used? Same with asymptotes.
Write the derivative as ##f'(x) = \frac{\text{stuff}}{(x - 1)^2} e^{-x/2}##. f' will be zero at the places where "stuff" is zero. That's what I was talking about when I said to approximate where the numerator is zero.
You could also look at ##g(x) = \frac{(x - 4)(x - 3)}{x - 1}##, (ignoring the exponential term temporarily). Multiplying by ##e^{-x/2}## will have the effect of "scrunching" the graph of g down as you move to the right. Just a thought...
Likes Vitani11
Thank you
Vitani11 said:
Thank you
In fact, "stuff" = a cubic polynomial, so is relatively easy to deal with. Its roots are not "nice", however, but there are three of them, all real.
Likes Vitani11
Okay... so I've gotten down to that part. I am told that my best bet to approximate the roots of this cubic is to use Newtons method since it is not factorable. But without cheating (by graphing, wolfram, etc.) how am I to come up with an initial value to do the approximation? What about a linear approximation?
You can calculate a few example values. Every time the sign changes there has to be a root in between.
Likes Vitani11
Got it! Wooo! Last question, what does it mean to find a point when a function "blows up?" Just where the limit approaches infinity around the asymptote, so the x coordinate of where the asymptote is located?
Yes. The function "blows up" because one factor in the denominator is getting close to zero.
Likes Vitani11
You can apply Descarte's Rule of signs to your polynomial ##p(x)## conclude that for positive ##x## there are either 3 roots or 1 root, and for negative ##x## there are no roots. In fact, since ##p(0) = -2## and ##p(1) = 12,## the point ##x = 0## must be pretty close to a root; thus, starting Newton from 0 seems a good choice.
Related to Finding the max/min values of this function?
What is the purpose of finding the max/min values of a function?
Finding the max/min values of a function is important because it helps to determine the extreme or critical points of the function, which can provide valuable information about the behavior and characteristics of the function.
How do you find the max/min values of a function?
To find the max/min values of a function, you can use various methods such as setting the derivative of the function equal to zero, using the first or second derivative tests, or graphing the function and identifying the highest and lowest points.
Why is it important to consider the domain when finding the max/min values of a function?
The domain of a function determines the set of values for which the function is defined. When finding the max/min values, it is important to consider the domain because the function may have multiple max/min points outside of the given domain, which would not be relevant to the problem at hand.
Can a function have more than one max/min value?
Yes, a function can have multiple max/min values. This can occur when the function has multiple critical points or when there are multiple points on the function with the same y-value, known as relative extrema.
What is the difference between a local and a global max/min value?
A local max/min value is a point on the function that is the highest or lowest within a specific interval or range. A global max/min value, also known as an absolute max/min, is the highest or lowest point on the entire function. A local max/min value may or may not also be a global max/min value.
