Finding the minimum of a 2 variable function.
In summary, the conversation discusses finding the absolute minimum value of a function on a bounded set using partial derivatives and the theorem that states a continuous function on a closed bounded set in R(2) has an absolute maximum and minimum. The discussion also covers finding critical points and determining if they represent a minimum, maximum, or saddle point. The person speaking is used to finding the minimum and maximum by sketching a graph with the boundaries and solving for the constant variables. However, in this case, they are unsure of how to proceed with the given boundaries and critical point.
MarcL
170
ind the absolute minimum value of the function f(x,y) = 6 + 3xy -2x- 4y on the set D. D is bounded by the parabola y=x^2 and y=4
Partial derivatives and a theorem where if F is continuous on a closed bounded set in R(2) then F has an abs. max and abs. minimum
I found the partial derivative in accordance to x and y:
Fx=3y-2
Fy=3x-4
I found the critical points ( when Fx and Fy = 0) being (4/3 3/2). However, I get stuck when sketching the graph. I am used to sketching a square/ rectangle ( with the boundaries) and dividing it into 4 lines and solving for each with my function. In this I get:
F(x,x^2)= 6+x^3-2x-4x^2 but then I don't know how to find the smallest value for that, as my x is good for all real numbers no?
You are right that only critical point is x = 2/3 y = 4/3. Surely you can sketch y = ##x^2## and y = 4?
Is (2/3,4/3) in this area or not? If so, it may represent a min, a max or a saddle. Do you know how to determine which you have?
If it is a max or a saddle, your min will definitely occur on the boundary, and we can get back to that in the next step.
Likewise, if it is a min, the absolute min may still occur on the boundary, or maybe this critical point is it. We have to check that.
So if you can get this first step done, we can look next at the boundary situation.
hum, 2/3 and 4/2 does lie in those 2 boundaries, I mean the parabola is from (-16,4) to (16,4) ( If I graphed it). However I never took this approach to those problem ( which leads me to ask why we ever found the critical point as we didn't use them in our answer).
We usually sketched the "region" the describes the boundaries and solve for the function when either the x or y is constant and then use the boundary to find the lowest or highest value.
As for this example, I think it is just a saddle, but it's a "guestimate". I mean if I plug in my 2 "furthest point" (-16,4) and (16,4) I get a lower / higher point. Don't know if I am looking at this the right way?
Your work is riddled with errors. The critical point is at (2/3,4/3) not (2/3,4/2) or (2/3,3/2) both of which you've stated. And neither (-16,4) nor (16,4) is even in your region. Draw a graph. What are the real x values that bound your region? As brmath said, if you can show that's a min using the second derivative test then you don't need to check the boundary. It's not (what is it?). So you do need to check the boundaries. That f(x,x^2)= 6+x^3-2x-4x^2 is also wrong for the parabola boundary. Correct that too. What's the function along y=4?
First, it was a typo, I did get the critical point you just pointed out so my apologies for that.
If you draw the graph out the parabola does meet the line y=4, I meant the parabola meets the line at x=-2 and x=2 ( my bad also on that, I squared 4 for some reasons...)
Again, the only method I used in my cal 3 class to find the abs. minimum and max was to draw a "graph" with the boundaries on it.. So it would give me , in all the cases we covered, a rectangle / square where every vertices would be one of the boundaries... So for instance if 0</= x </= 2 and 1</=y</= 2 I would have
(0,1), (0,2), (2,1),(2,2). After, I would separate the rectangle in 4 lines, and then solve for on every line for which variable is constant...
SO in THIS case, I did it with the fact that I have 2 lines after sketching my boundaries. L1 : y=4 and L2 y=x^2
so for L2: f(x,x^2)= 6+3x^2-2x+4x^2... That was how I was taught...
Then l1: f(x,4)= 6+12x-2x+16... But this is the only method I was taught. I don't even know what is the point of finding my critical point as it looks to be a saddle point. (in this case)
Indeed it is a saddle point. If you don't know the second derivative test then ok, then just check the value at your critical point f(2/3,4/3) and the minima along your boundary curves. But those have errors in them as well. Are you even sure your original function is f(x,y)=6+3xy-2x-4y? Or is there a typo there as well? It's really hard to work around all this error noise.
oh yeah the second derivative test, I remember, whoops ( been forever and reviewing for finals). As for the rest of the info, they are right.
As for the 2nd derivative test, it only applies to local max and min , in this question I'm being ask for absolute min. So I don't think I can use it ( correct me if I'm wrong)
You don't HAVE to use the 2nd derivative test. You do HAVE to use the critical point somehow. The minimum could be either along the boundary or at the critical point. IF you know the critical point is a saddle point using the 2nd derivative test, then you would know the minimum is not at the critical point. But you can't know that until you find the critical point and show it is a saddle point. Get me? You do have to always find critical points. You can't generally know they aren't what you are looking for until you find them.
In this case, when I apply the second derivative test, I get D as a constant ( I don't know if I am doing it wrong..)
Fx= 3y-2 therefore Fxx= 0 and samething goes for y. So I assumed my critical point was a saddle, afterwards however, I don't know what other points to use to find my abs. max and min.
Whether there is a max, min or saddle at the critical points, you do need to check the boundary. A min at a critical point can be a local min, so it may be that the abs min is on the boundary.
To check the boundary, you have 2 cases: y = ##x^2## and y = 4. Each case allows you to express f as a function of 1 variable, so you can find the minimum using ordinary 1 dim calculus. Whichever minimum is smaller is your absolute min.
Re your second derivative test, you should revisit the criteria. If D > 0 you have either a min or a max depending on whether the Jacobian matrix is positive or negative definite. If D < 0 you have a saddle. If D = 0 the test fails -- you can't conclude anything from it.
##f_{xy}## isn't zero. But yes, D is constant and negative. it's a saddle. Now check the boundary! Your min must be there.
Related to Finding the minimum of a 2 variable function.
1. What is the minimum value of a 2 variable function?
The minimum value of a 2 variable function is the smallest output or dependent variable that the function can produce for any given input or set of inputs.
2. How do you find the minimum of a 2 variable function?
To find the minimum of a 2 variable function, you can either use calculus to find the critical points and then determine which one is the minimum, or you can use graphing or numerical methods to approximate the minimum value.
3. What is the significance of finding the minimum of a 2 variable function?
Finding the minimum of a 2 variable function is important in many fields of science and engineering, as it allows us to optimize and improve upon various systems and processes. It also helps us understand the behavior and relationships between two variables in a given system.
4. Can the minimum of a 2 variable function change?
Yes, the minimum of a 2 variable function can change if the function itself or the values of the input variables change. This is why it is important to regularly evaluate and update the minimum value to ensure optimal performance.
5. Is there a specific method that is best for finding the minimum of a 2 variable function?
The best method for finding the minimum of a 2 variable function depends on the specific function and the available resources. Calculus provides an exact solution, while graphing and numerical methods offer approximations. It is best to use a combination of methods to verify and refine the minimum value.
