Finding the Minimum Value of a Complex Expression
In summary, the minimum value is the smallest possible value in a given set of data or a mathematical equation. It can be determined by finding the lowest number in a set of data or by using calculus to find the minimum point on a graph. It is important to determine the minimum value to understand the range and variability of the data and to make optimized decisions. Multiple minimum values can exist in some cases, and there is a difference between absolute minimum value (smallest overall) and relative minimum value (lowest point in a specific interval or region).
anemone
MHB
POTW Director
3,883
115
Determine the minimum value of $\left( \sqrt{x^2-8x+27-6\sqrt{2}}+ \sqrt{x^2-4x+7-2\sqrt{2}} \right)^4$ where $x$ is a real number.
Mathematics news on Phys.org
Let
$$f(x)= \left( \sqrt{x^{2}-8x+27-6 \sqrt{2}}+ \sqrt{x^{2}-4x+7-2 \sqrt{2}} \right)^{4},$$
and let
\begin{align*}
g(x)&=x^{2}-8x+27-6 \sqrt{2} \\
h(x)&=x^{2}-4x+7-2 \sqrt{2}.
\end{align*}
By completing the square, we can determine that $g(x)>0$ and $h(x)>0$ for all $x \in \mathbb{R}$. Hence, $ \mathcal{D}(f)= \mathbb{R}$.
Since the fourth root function is monotone increasing, it follows that $f(x)$ has a minimum at the same location as $\hat{f}(x)= \sqrt[4]{f(x)}$.
Taking the derivative $\hat{f}'(x)$ and setting it equal to zero yields the equation
$$(x-4) \sqrt{x^{2}-4x+7-2 \sqrt{2}}+(x-2) \sqrt{x^{2}-8x+27-6 \sqrt{2}}=0.$$
Squaring both sides and expanding out yields the equation
$$(4 \sqrt{2}-8)x^{2}+(8 \sqrt{2}-20)x+8 \sqrt{2}-4=0.$$
The solutions are
$$x=1+ \sqrt{2} \quad \text{or} \quad x= \frac{4- \sqrt{2}}{2}.$$
Plugging these values into $\hat{f}$ yield
\begin{align*}
\hat{f}(1+ \sqrt{2})&=2 \sqrt{2} \approx 2.8284 \\
\hat{f}((4- \sqrt{2})/2)&= \frac{ \left((31-8 \sqrt{2}) \sqrt{31+8 \sqrt{2}}
+(49-28 \sqrt{2}) \sqrt{7+4 \sqrt{2}} \right) \sqrt{34}}{2 \cdot 7 \cdot 17}
\approx 3.9569.
\end{align*}
Hence, the minimum of $f$ is $(2 \sqrt{2})^{4}=(2^{3/2})^{4}=64.$
Ackbach said:
Let
and let
\begin{align*}
\end{align*}
The solutions are
\begin{align*}
\approx 3.9569.
\end{align*}
Wow...what a brilliant way to tackle this challenge problem, well done, Ackbach!:cool:
I learned something valuable from your method, thank you for your solution and thank you for participating!:)
FAQ: Finding the Minimum Value of a Complex Expression
What is the minimum value?
The minimum value refers to the smallest possible value in a given set of data or a mathematical equation.
How do you determine the minimum value?
The minimum value can be determined by finding the lowest number in a set of data or by using calculus to find the minimum point on a graph for a mathematical equation.
Why is it important to determine the minimum value?
Determining the minimum value allows us to understand the range and variability of a set of data. It also helps us to optimize and make decisions in situations where we want to minimize a certain variable.
Can there be more than one minimum value?
Yes, in some cases there can be multiple minimum values. For example, in a set of data with two or more equally low values, all of them can be considered as minimum values.
What is the difference between absolute minimum value and relative minimum value?
The absolute minimum value is the smallest value in a set of data or on a graph, while the relative minimum value is the lowest point in a specific interval or region of the data or graph.
