Finding the Minimum Value of a Summation with a Constant Term
In summary: Yes, they are equivalent.In summary, the minimum value of $\sum_{i}^{n}(x-a_i)^2$ is $-\frac{A^2}{n^2}+\frac Bn=-\frac{\left(\sum_{i=1}^{n}[a_i]\right)^2}{n^2}+\frac{\sum_{i=1}^{n}[a_i^2]}{n}$.
Dethrone
717
Given $a_1,...,a_n$, find the minimum value of $\sum_{i}^{n}(x-a_i)^2$
No idea how to do it. I was thinking maybe when $x-a_i=0$, but I think $x$ is constant so it won't work...unless the series $a_n$ is constant too...Tiny hint please :D?
Okay, a tiny hint:
Begin by expanding the summand and exploiting the linearity of the summation operator.
Umm...(Wondering)
Expanding the summand:
$$\sum_{i}^{n}(x-a_i)^2=(x-a_1)^2+(x-a_2)^2+(x-a_3)^2+...+(x-a_n)^2$$
Not sure how to exploit it...just a guess:
$$=nx^2-2x(a_1+a_2+...+a_n)+(a_1^2+a_2^2+...+a_n^2)$$
You are moving in the right direction, although you have an error (that you have since fixed). But, what I meant is to write:
\(\displaystyle f(x)=\sum_{i=1}^{n}\left[\left(x-a_1\right)^2\right]\)
Now, expand the summand:
\(\displaystyle f(x)=\sum_{i=1}^{n}\left[x^2-2a_ix+a_i^2\right]\)
Exploit the linearity of the summation operator:
\(\displaystyle f(x)=\sum_{i=1}^{n}\left[x^2\right]+\sum_{i=1}^{n}\left[-2a_ix\right]+\sum_{i=1}^{n}\left[a_i^2\right]\)
Factor out those factors not dependent on the index of summation, to get a quadratic in $x$:
\(\displaystyle f(x)=x^2\sum_{i=1}^{n}\left[1\right]-2\sum_{i=1}^{n}\left[a_i\right]x+\sum_{i=1}^{n}\left[a_i^2\right]\)
\(\displaystyle f(x)=nx^2-2\sum_{i=1}^{n}\left[a_i\right]x+\sum_{i=1}^{n}\left[a_i^2\right]\)
Now, minimize...
Note: every summand is enclosed by square brackets, but they do not display properly for some reason. :D
Oh! I was going to write something similar to that, but I thought it was being a bit fancy for something that could be potentially wrong. (Dull)
$$\displaystyle f(x)=nx^2-2\sum_{i=1}^{n}\left[a_i\right]x+\sum_{i=1}^{n}\left[a_i^2\right]$$
$$f'(x)=2nx-2\sum_{i=1}^{n}\left[a_i\right]$$
Setting equal to zero:
$$x=\frac{\sum_{i=1}^{n}\left[a_i\right]}{n}$$
Is that right?
Yes, that is your critical value. How do you know this is at the minimum without using calculus?
I like that question! :D
Can I simply say that because there is only one critical number and the function tends to infinity as you approach its boundaries, then the extrenum must be a minimum? The function being a positive quadratic should be just enough, actually.
The function you are minimizing is of the form $f(x) = nx^2 - 2Ax + B$. Since $n > 0$, if we find $x$ that min $f(x)$, it will also min $x^2 - \frac{2A}n x + \frac Bn$. We can then just complete the square:
$x^2 - \frac{2A}n x + \frac{A^2}{n^2} - \frac{A^2}{n^2} + \frac Bn = \left( x - \frac An \right)^2 - \frac{A^2}{n^2} + \frac Bn$.
With $A,B,n$ fixed, the smallest value can be attain when that square is $0$,
or $x = \frac{A}n$. In the case of this problem, it is $\frac 1n \sum_i a_i$, which we note is the average of the $a_i$'s.
Rido12 said:
...The function being a positive quadratic should be just enough, actually.
That's what I was hinting at, you have an upward opening parabola, so the critical value must be at the minimum.
Now, the question asks you to find the minimal value, so what do you get?
Hi Mark! (Wave)
So plugging $x$ in, we get:
$$\sum_{i=1}^{n}\left(\frac{\sum_{i=1}^{n}\left[a_i\right]}{n}-a_i\right)^2$$
Not sure if it is wise to simplify further. Looking back at magneto's method of completing the square, I see $- \frac{A^2}{n^2} + \frac Bn$, which also should be the minimum value.
$$- \frac{A^2}{n^2} + \frac Bn=-\frac{\left(\sum_{i=1}^{n}[a_i]\right)^2}{n^2}+\frac{\sum_{i=1}^{n}[a_i^2]}{n}$$
Are these statements equivalent?
FAQ: Finding the Minimum Value of a Summation with a Constant Term
What is the minimum value of a summation?
The minimum value of a summation is the smallest possible result that can be obtained by adding a series of numbers together. It is the lower bound or limit of the summation.
How is the minimum value of a summation calculated?
The minimum value of a summation is calculated by taking the smallest number in the series and adding it to the second smallest number, then adding the third smallest number to the result, and so on until all numbers have been added. The final result is the minimum value of the summation.
Can the minimum value of a summation be negative?
Yes, the minimum value of a summation can be negative if the series of numbers being added together includes negative numbers. In this case, the minimum value will be the sum of all the negative numbers in the series.
How does the minimum value of a summation relate to the maximum value?
The minimum value of a summation is the opposite of the maximum value. While the minimum value is the smallest possible result, the maximum value is the largest possible result that can be obtained by adding the same series of numbers together.
What is the significance of finding the minimum value of a summation?
Finding the minimum value of a summation can help in identifying the most efficient solution to a problem. It can also provide insight into the behavior and patterns of the numbers being added together, and can be used in various mathematical and scientific applications.
