Finding the molecular formula of a hydrocarbon
In summary, the conversation discusses the proportionality between moles and volume, specifically in the case of a reaction involving carbon dioxide gas and water vapor. It is determined that there is 800 cm3 of carbon dioxide and a stoichiometric ratio of 4:1 between carbon dioxide and the hydrocarbon in the reaction. However, there is confusion about the stoichiometric ratio of water to the hydrocarbon and whether water is produced as a gas or liquid in the reaction.
i_love_science
80
The molecular formula of a gaseous hydrocarbon can be determined by combusting it completely in excess oxygen and then passing it through potassium hydroxide solution to absorb the carbon dioxide produced. In an experiment, 200 cm3 of a hydrocarbon was reacted with 1500 cm3 of oxygen. After the hydrocarbon had combusted completely, 1000 cm3 of gas remained. The volume was reduced to 200 cm3 after the gas had been passed through a solution of potassium hydroxide. All volumes were measured under the same conditions of temperature and pressure. Deduce the formula of the hydrocarbon.
Avogadro's law
Moles are proportional to volume. There is 1000 cm3 of gas (carbon dioxide gas plus water vapour) after the reaction, and 200 cm3 of water vapour after the carbon dioxide has been absorbed. Therefore, there is 800 cm3 of carbon dioxide. Since the stoichiometric ratio of carbon dioxide to the hydrocarbon is 800:200 = 4:1, then the hydrocarbon formula should have 4 carbons.
I'm stuck on the following:
The stoichiometric ratio of carbon dioxide to the hydrocarbon is 200:200 = 1:1, so there should be 2 hydrogens in the formula. This is not reasonable, could someone explain where I went wrong?
Also: does combustion usually produce water vapour or liquid water?
Thanks.
What about excess oxygen?
Generally speaking we assume (unless told otherwise) that gases were measured around STP, so water was in a liquid form and didn't count into volumes.
That's OK.
Yes.
No, as you wrote earlier it is 4:1, not sure what you do here.
Unless you mean water:hydrocarbon ratio, but then you are wrong. Think again about the identity of the excess gas.
Related to Finding the molecular formula of a hydrocarbon
What is a hydrocarbon?
A hydrocarbon is a type of organic compound that is made up of hydrogen and carbon atoms. These atoms are bonded together in a specific ratio, which determines the properties and structure of the hydrocarbon.
How do you find the molecular formula of a hydrocarbon?
The molecular formula of a hydrocarbon can be determined by analyzing its molecular structure and the number of atoms of each element present in the compound. This can be done through various methods such as mass spectrometry, elemental analysis, and NMR spectroscopy.
Why is it important to know the molecular formula of a hydrocarbon?
Knowing the molecular formula of a hydrocarbon is important because it provides information about the composition and structure of the compound. This information is crucial in understanding the physical and chemical properties of the hydrocarbon and its potential uses.
Can the molecular formula of a hydrocarbon change?
No, the molecular formula of a hydrocarbon cannot change. The number and types of atoms present in a compound determine its molecular formula, and these cannot be altered without breaking the chemical bonds within the compound.
What are some common examples of hydrocarbons?
Some common examples of hydrocarbons include methane (CH4), propane (C3H8), and octane (C8H18). These compounds are commonly found in natural gas, gasoline, and other fossil fuels.
