Finding the number of electrons?
  • Thread starter Thread starter Arij
    Electrons
To find the number of electrons passing through a wire with only resistance given, one must use the relationship between voltage (V), current (I), and resistance (R) through Ohm's Law (V=IR). The current can be expressed as I = dQ/dt, where dQ is the charge and dt is the time interval. The number of electrons (n) can be calculated using the equation n = Q/e, where e is the elementary charge. The discussion highlights that while V and time (t) must be assumed, their specific values are less critical as long as they maintain a consistent relationship. The challenge lies in ensuring dimensional consistency when substituting values into the equations.
Arij
I was asked to find number of electrons passing through a wire giving only resistance.
V=IR
I = dQ/dt
n= Q/e
It's pretty straight forward, with direct substitution of the equations with the written order.
I could attempt this assuming V = 1 V but, is there another way to get this with only the value of R and I'm not seeing it??
Do note that you also have to assume the time (t) as well as the voltage.
Therefore I believe the values of V and Time(t) don't matter so long as they have a relationship such that V times Time t gives you 1, given the relationship they have in the derived equation.
forgot to mention that he did mention it's number of electrons passing through xx ohms in one second.
Correct me if wrong, your suggestion is:
n=Q/e=Idt/e= (V/R)dt/e=(V/dt) R/e and assuming V/dt = 1 but I'm not how does that work if I look at it dimensionally using units.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
