Finding the number of ways in which a group can take exams?
  • Thread starter khurram usman
  • Tags
    Exams Group
In summary: That is a sum of 3 terms (corresponding to the 3^45 different class-lists) each of which is a multinomial coefficient. There is no closed-form answer for that sum. The sum is the 45th power of 3.
khurram usman
87
A group of 45 Computer Science students at a particular University had to
take their first Discrete Mathematics course in the Autumn, Winter or
Spring quarter of their Freshman year. How many possible ways were
there for this group to meet this requirement?
i came across this question on the web while preparing for my exam. how do i approach this ?
also is there any good resource of solved problems for discrete mathematics problems on counting,set theory etc.?
any help is appreciated.
The question is not well-defined. For example, one can have 15 students in the course in each term. Does that count as ONE way, or many, many ways, depending on how the 45 individual names are assigned to the three terms---that would be 53494979785374631680 different ways! Which interpretation is meant? (You could, of course, try to solve both versions.)
i think that the second version is wanted. how did you get this huge number?
i was thinking that we have 45 objects and we have to divide them into three groups. we have to find the total number of such groups.
so we have 45 objects and we have to insert 2 sticks in between essentially dividing them into 3 groups. so the total number should be (45+2)C(2) that is 47C2.
this comes out to be 1081
is this approach wrong?
The number of distinct ways of splitting a group of N distinguishable items into three groups of sizes n1, n2, n3 (with n1 + n2 + n3 = N) is N!/(n1! * n2! * n3!). So, a group of 45 individuals can be assigned to three groups of 15 each in 45!/(15!)^3 ways.
This is quite easy to see. The number of distinct first groups is N!/(n1! * (N-n1)!) = binomial coefficient C(N,n1). Now, given the N-n1 remaining items not in the first group, the number of ways of putting them into group 2 is C(N-n1,n2) = (N-n1)!/(n2! *(N-n1-n2)!). Therefore, the number of ways of forming the three groups is C(N,n1)*C(N-n1,n2) = the formula I gave before.
That gives the number of ordered group sizes. I.e. how many students attend each offering, where you discriminate the offerings but not the students. Thus, attendances (14,15,16) is different from (16,15,14).
Ray's 45!/(15!)^3 is for where the attendances are fixed at (15,15,15) and the students are discriminated. But I don't see anything in the problem statement that fixes that attendance pattern.
If we discriminate students but there are no constraints on attendance pattern, each student can select an offering independently of the others, leading to a much larger number.
You say you wanted the second version, but your calculation is for the first version. That is why there is such a huge difference between the two counts.
One way of counting (where you just want to know the class sizes) would be the problem faced by a resource-allocation planner who needs to assign resources to the classes based on enrollment numbers. The number of different resource-allocation packages is equal to the number you tried to calculate above.
Another way of counting would be the problem of determining the different numbers of class-lists, where you not only specify the class sizes but also the individual students in the class. In this problem there are 3^45 = 2954312706550833698643 different possible class lists. This is obtained by summing ##N!/(n_1! n_2! n_3!) \; (N = 45)## over those ##n_i \geq 0## that sum to ##N##. You can do the sum by using the trinomial expansion.
FAQ: Finding the number of ways in which a group can take exams?
What is the formula for finding the number of ways in which a group can take exams?
The formula for finding the number of ways in which a group can take exams is nPr = n! / (n-r)!, where n is the total number of exams and r is the number of exams the group will take.
How do I use the formula to calculate the number of ways a group can take exams?
To use the formula, simply plug in the values for n and r and solve the equation. For example, if there are 10 exams and the group will take 3 of them, the calculation would be 10P3 = 10! / (10-3)! = 10! / 7! = 720.
What is the difference between permutations and combinations when calculating the number of ways a group can take exams?
Permutations take into account the order in which the exams are taken, while combinations do not. In other words, permutations consider each exam as a unique event, while combinations see the group taking a set number of exams without regard to the specific order.
Can the formula be used for any number of exams and group size?
Yes, the formula works for any number of exams and group size. However, it is important to note that the group size should not be larger than the total number of exams, as this would result in a negative value for r in the equation.
Are there any other factors to consider when using this formula to calculate the number of ways a group can take exams?
Yes, it is important to consider any restrictions or limitations on the exams that may affect the total number of ways the group can take them. For example, if certain exams can only be taken by a certain group or at a specific time, this would affect the final calculation.
