MHB Finding the $p$ Closest Elements to Median of Set $M$ in $O(m)$ Time
The discussion centers on developing an algorithm with a time complexity of O(m) to identify the p closest numbers to the median of a set M containing m numbers. The initial query seeks guidance on how to achieve this efficiently. A key point raised is the challenge of operating within O(m) time while determining the median, as the median is defined as the middle value of a sorted list. However, it is noted that finding the median can indeed be done in O(n) time using the "median of medians" approach. The proposed algorithm involves defining a range around the median to identify potential candidates for the closest numbers but acknowledges that this range may include more than the required p elements. The discussion concludes with a need to refine the method to extract the p nearest elements from the identified interval.
evinda
MHB
Hello! (Wave)
I want to describe an algorithm with time complexity $O(m)$ that, given a set $M$ with $m$ numbers and a positive integer $p \leq m$, returns the $p$ closest numbers to the median element of the set $M$.
How could we do this? (Thinking)
Technology news on Phys.org
What could we do in order to find the $p$ closest numbers to the median element of the set $M$ ? Could you give me a hint? (Thinking)
evinda said:
Hello! (Wave)
Complexity $O(m)$ algorithm operating on a list of size $m$ implies that you're only allowed to do a single pass of the list. Is this list of numbers pre-sorted or not?
No, I think that the algorithm should work for each case... (Thinking)
Without thinking about it in depth, I'm not sure that this is possible. Median is the "middle" value on a set of ranked values, and no sorting algorithm runs in $O(n)$ time.
EDIT: I'm wrong. It's possible to find the median in $O(n)$ time. See if this helps you: Median of medians - Wikipedia, the free encyclopedia
Doing it like that:
Code:
low=m/2-(p-1)
high=(m-1)/2+(p-1)
Algorithm(A,begin,end,low,high){
  if (begin<end){
      k=medianofMedians(A,low,high)
      q=hoare(A,start,begin,end,k)
      if (q>low) Algorithm(A,begin,q-1,low,high)
      if (q<high) Algorithm(A,q+1,end,low,high)
we will have the interval to which the $p$ elements we are looking for belong.
But this interval will contain $2p$ elements.
How can we find the $p$ nearest elements to the median? (Sweating)
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
