Finding the parameters for Harmonic Oscillator solutions
In summary, the conversation discusses using the Schrödinger equation to find the parameter α of the Harmonic Oscillator solution Ψ(x)=Axe−αx2, which is the first excited state of a 1-D quantum harmonic oscillator with energy 3/2ħω. The equation must be satisfied for all values of x, indicating that there is only one specific value of α and E that can make this possible. By grouping together terms of like powers in x and using the fact that a polynomial must have all coefficients equal to zero in order for it to equal zero for all x, the specific values of α and E can be found.
gabu
Using the Schrödinger equation find the parameter [itex]\alpha[/itex] of the Harmonic Oscillator solution [itex]\Psi(x)=A x e^{-\alpha x^2}[/itex]
[itex]-\frac{\hbar^2}{2m}\,\frac{\partial^2 \Psi(x)}{\partial x^2} + \frac{m \omega^2 x^2}{2}\Psi(x)=E\Psi(x)[/itex]
[itex]E=\hbar\omega(n+\frac{1}{2})[/itex]
Using the Schrödinger equation we have arrive at
[itex] -2\alpha (2x^2\alpha-3)+\frac{m^2\omega^2x^2}{\hbar^2} = \frac{2m}{\hbar^2}E[/itex]
If I make x=0 I obtain
[itex] \alpha = \frac{m\omega}{2\hbar} [/itex]
using the information that the energy level of the oscillator is the same as the highest power in the solution, meaning [itex] E=3\hbar\omega/2 [/itex].
Now, my problem with this solution is the need to make x=0 to arrive at it. I know that the equation holds for every x, so it is justifiable to consider the origin. The thing is, however, that shouldn't I be able to solve the equation without this assumption? Shouldn't it be independent of x?
Thank you very much.
Hello.
This equation must be satisfied for all ##x##. This can be true only for one specific value of ##\alpha## and one specific value of ##E##.
Group together terms of like powers in ##x## to form a polynomial in ##x##. Use the fact that if a polynomial in ##x## is equal to zero for all values of ##x## in some finite domain, then each coefficient in the polynomial must be zero.
Likes gabu
gabu said:
Using the Schrödinger equation find the parameter αα\alpha of the Harmonic Oscillator solution Ψ(x)=Axe−αx2Ψ(x)=Axe−αx2\Psi(x)=A x e^{-\alpha x^2}
This is actually the first excited state of a 1-D quantum harmonic oscillator having energy 3/2ħω
Where α is mω/2ħ
TSny said:
Hello.
Oh, I can see now. Thank you very much.
Related to Finding the parameters for Harmonic Oscillator solutions
1. What is a harmonic oscillator?
A harmonic oscillator is a system that exhibits periodic motion around an equilibrium point, where the restoring force is directly proportional to the displacement from the equilibrium point. It can be described mathematically using the harmonic oscillator equation, which involves parameters such as mass, spring constant, and damping coefficient.
2. Why is it important to find the parameters for harmonic oscillator solutions?
Finding the parameters for harmonic oscillator solutions allows us to accurately model and predict the behavior of physical systems that exhibit harmonic motion. This is important in various fields such as physics, engineering, and chemistry.
3. How do you find the parameters for harmonic oscillator solutions?
The parameters for harmonic oscillator solutions can be found through experimental measurements or by solving the harmonic oscillator equation using mathematical methods such as differential equations or linear algebra.
4. What are some common techniques for finding the parameters for harmonic oscillator solutions?
Some common techniques for finding the parameters for harmonic oscillator solutions include the use of graphical methods, such as plotting position vs. time or velocity vs. time graphs, and using curve fitting algorithms to determine the best fit for the data. Numerical methods, such as the Euler method or the Runge-Kutta method, can also be used to solve the harmonic oscillator equation and determine the parameters.
5. Can the parameters for harmonic oscillator solutions change over time?
Yes, the parameters for harmonic oscillator solutions can change over time due to external factors such as changes in temperature, friction, or external forces. This can result in changes in the amplitude, frequency, and phase of the harmonic motion.
