Finding the percent weight an element in an Alloy
In summary, Homework Equations require mass of Aluminum and Lithium to be known and the density of the alloy to be determined. The attempted solution to this problem found that for a 100 gram sample, the volume is equal to 2.55 grams of alloy multiplied by the density.
KMjuniormint5
67
Determine the wt% of lithium required to obtain an Al-Li alloy with a density of 2.55 g/cm^3.
I am so lost in this problem, any hints of how to start this problem with GREATLY appreciated!
Could you use the individual densities of Aluminum and of Lithium? They should be listed in a handbook. Maybe try setting up a chart or table for a given number of grams or cubic centimeters of all materials involved.
As Symbolipoint suggests, you are most likely expected to assume that mass of the mixture is sum of the masses of components (always true) and sume of the volumes is the sum of the volumes. The latter assumption is only an approximation, as volumes are in general not additive (google "ethanol water volume contraction").
so in this problem I am allowed to assume I can add the two volumes together?
so say:
V(Al)+V(Li)=V(total)
Unless you were just discussing volume contraction tables or excess volumes - which can be part of some advanced physical chemistry course - yes.
ok i have almost got it . . .for some odd reason I am just unable to solve for the mass of each element. No idea why . . .but I just realized that someone else has posted the same problem . . .sorry, still new to this forum. I saw he got
mass Al = 2.7VAl
mass Li = .543VLi
I have no clue where he got those two. Its been a long time since I have taken chemistry . .
Show your system of equations.
V(Al)+V(Li)=5 mL (where 5 is just an arbitrary number)
solve for each:
V(Al)=5-V(Li)
V(Li)=5-V(Al)
Volume is not enough. You need another equation, that will combine volumes and densities.
Reread my first post in this thread.
density = mass/volume
saying that 1mL of each
2mL total
mass of Al = 2.7*1= 2.7 grams
mass of Li =0.534*1= 0.534 grams
mass of the entire system = (2.55)*2 = 5.1 grams
putting that into the equation:
Mass(Li)*Volume(Li)+Mass(Al)*Volume(Al)=5.1
solving gets to about 1.45 percent weight of Li?
This is chaotic. You first assume you have to mix 1mL of each, then you list their masses, suggesting that 2.7+0.534=5.1 (no, it doesn't equal). Then you write some unrelated equation...
Hard to follow, if possible. Could be you think OK, but you have to show it. Slow down.
You have to mix VLi and VAl, these are your unknowns (alternatively your unknowns can be mLi and mAl). Decide which unknowns do you use, then write equations that you want to use. Write them here.
mass Al = 2.7V(Al)
mass Li = .543V(Li)
V(Al)=2-V(Li)
V(Li)=2-V(Al)
putting the 4 equations together if the form of:
Volume(Li)+Volume(Al)=2 mL
Mass(Li)/Density(Li)+Mass(Al)/Density(Al)=Mass/Density
0.534(2-V(Al))/0.534+2.7*(2-V(Li))/2.7=5.1/2.55
**This is where I think go wrong**
OK
It is not wrong, it just doesn't make sense. You have substituted both volumes by (2-other volume) - do it with one volume only, you will get one equation in one unknown.
[0.534(V(Li))/0.534]+[2.7*(2-V(Li))/2.7]=[5.1/2.55]
but in this case doesn't everything cancel?
Everything cancels out. I got lost in the chaos.
This is again equation for sum of volumes. You have already used it.
Write equation for the sum of masses. That's what I suggested in my first post, that's what I asked you to do 3 hours ago.
ok you that's what started to do but for some odd reason. . .im stupid:
Mass(Li)+Mass(Al)=Mass
density(Li)*volume(Li)+density(Al)*volume(Al)=(density)*(volume)
0.534*V(Li)+2.7*(2-V(Li))=2.55*2
solving for Volume one gets .13876 mL
and to get mass (.534*.13876)=0.0741 grams
How he expresses what he is thinking is difficult to follow, but he seems to be thinking correctly - at least mostly correctly. The stated result of 1.45% Lithium is correct.
Try to follow this: Assume 100 grams of alloy, use m1 for mass of lithium and m2 for mass of aluminum. For this 100 grams, continuing with d for density, and v for volume, we can say that the volume of this 100 gram of alloy is
(m1/d1 + m2/d2)
We know the given density of the alloy of 2.55 grams/cubic centimeter, so we can say
(m1 + m2)/(m1/d1 + m2/d2) = 2.55
The other equation which we can use is for the assumed arbitrary 100 g. sample,
100 = m1 + m2
Those are the two equations in two unknowns. The rest is simple properties of equality for Real numbers; a few tedious but easy algebra steps. We could find two equivalent expressions for m2 from each equation, equate those expressions, and then find the resulting formula for m1. We will find the value which KMjuniormint5 did, 1.45%.
ok so my original thought of 1.45% was within the ballpark of an answer?
Looks like. I told you - you could be right, it was just hidden :wink:
Whenever you are trying to explain what you are doing try to write explicitely each step down. That may be tedious at first, but if you will get back later to what you wrote and you will try to understand it you will see where and why you are hard to follow - and you should learn then what can be left out, what has to be included to be sure others can understand.
ok i understand where the confusion comes into play as i was helping someone with physics on here. . . .thanks again for the help and getting me totally frustrated but in the end. . .i understand now where I need to go with problems like this. . .thanks so much kudos to ya
Related to Finding the percent weight an element in an Alloy
What is an Alloy?
An alloy is a mixture of two or more elements, at least one of which is a metal. Alloys are created to enhance the properties of a pure metal, such as strength, durability, or resistance to corrosion.
How do you find the percent weight of an element in an Alloy?
The percent weight of an element in an alloy can be found by dividing the mass of the element by the total mass of the alloy and multiplying by 100. This will give you the percentage of the alloy that is made up of the specific element.
What information do you need to find the percent weight of an element in an Alloy?
You will need the mass of the alloy and the mass of the specific element present in the alloy. This information can usually be found on the label of the alloy or through laboratory testing.
How is the percent weight of an element in an Alloy used?
The percent weight of an element in an alloy is important for understanding the properties and behavior of the alloy. It can also be used for quality control purposes to ensure that the alloy meets certain specifications and standards.
Are there any limitations to finding the percent weight of an element in an Alloy?
Yes, there are some limitations to this method. The mass of an element in an alloy can sometimes be difficult to measure accurately, which can affect the accuracy of the calculated percentage. Additionally, some alloys may contain elements that are difficult to distinguish from each other, making it challenging to determine the exact percentage of each element present.
11K
17K
