Finding the Period of a Function
In summary, the period of the function $\phi(x)$ is 8, but for non-constant continuous functions, the period can be arbitrarily small.
shen07
54
Hi guys,
I know that this question may be silly but could you please tell me how do i go about.
if $$\phi(2x+3)+\phi(2x+7)=10,\\\\\\\forall x\in\Re$$,find the period of $\phi(x)$.
Mathematics news on Phys.org
shen07 said:
Hi guys,
Setting $\displaystyle 2\ x + 3 = \xi$ You have that...
$\displaystyle \phi(\xi) = 10 - \phi (\xi + 4)\ (1)$
... but is also...
$\displaystyle \phi(\xi + 4) = 10 - \phi(\xi + 8)\ (2)$
Comparing (1) and (2) You arrive to write...
$\displaystyle \phi(\xi) = \phi(\xi + 8)\ (3)$
... so that the period of $\phi(*)$ is 8...
Kind regards
$\chi$ $\sigma$
Hi,
Certainly the previous response, \(\displaystyle \phi(x+8)=\phi(x)\) for all x, is true. However, you asked for the period of the function. Usually when we talk of the period of a function f, we mean the least positive p with f(x + p) = f(x) for all x (sometimes this is called the principal period). For example, the period of sin(x) is \(\displaystyle 2\pi\). Aside: if f is a non-constant continuous function and there is a positive p with f(x + p) = f(x) for all x, then there is a smallest such p; i.e. the period of f exists.
For your specific question, if \(\displaystyle \phi\) is a non-constant continuous function, the period can be an arbitrarily small positive value!
Example:
Let n be a positive integer, \(\displaystyle a={(2n+1)\pi\over4}\) and \(\displaystyle \phi(x)=\text{sin}(ax)+5\). Easily then \(\displaystyle \phi(x)+\phi(x+4)=10\) for all x, and so this function satisfies your equation. The period of this function is \(\displaystyle {2\over 2n+1}\), which can be made as small as desired by taking n sufficiently large.
FAQ: Finding the Period of a Function
What is the period of a function?
The period of a function is the distance between two consecutive peaks or troughs on a graph of the function. It represents the length of one complete cycle of the function.
How do you find the period of a function?
To find the period of a function, you first need to identify the frequency, which is the number of cycles per unit of the independent variable. Then, the period is equal to the inverse of the frequency. In other words, the period is the reciprocal of the frequency.
Can you find the period of any function?
Yes, the period can be found for any function, as long as it is a repeating pattern. This includes trigonometric functions, polynomial functions, and exponential functions.
What is the difference between period and frequency?
The period and frequency are inversely related. The period is the length of one complete cycle of a function, while the frequency is the number of cycles per unit of the independent variable. In other words, the frequency is the reciprocal of the period.
How does the period of a function affect its graph?
The period of a function determines the spacing between its peaks and troughs on a graph. A longer period means the function will repeat itself over a longer distance, resulting in a wider graph. A shorter period means the function will repeat itself over a shorter distance, resulting in a narrower graph.
