Finding the period of a sinusoid
  • Thread starter tade
  • Tags
    Period
In summary, the given equation is a product of two sinusoids, with k, ω, a, and v being positive real numbers. The period of the sinusoid can be found by considering the equation as a single trig function, with the value of a having no effect on the period. By simplifying the equation, it can be seen that j should be equal to nT, where n is an integer and T is a constant based on δ and ω. The resulting waveform is a form of amplitude modulation and is not a simple sinusoid, so the concept of period may vary depending on the specific need. Experimenting with different values of the parameters can help to understand the concept further.
tade
721
Let's have y = sin(k(a+vt))*sin(ωt)
where k, ω, a and v are all positive real numbers.
What is the period of this sinusoid in terms of k, ω, a and v?
Mathematics news on Phys.org
That's a good question - what have you tried?
i.e. what happens if you try to turn your product of sinusoids into a single trig function?
This is: ##A\sin k(x+vt)## where ##A=\sin\omega t## considered at point ##x=a## right?
Presumably ##\omega \neq kv## in this case?
In which case, you have an equation of form: $$y(t)=\sin(\omega_1 t + \phi)\sin(\omega_0 t) $$
But it still looks the same though.
I believe the value of a doesn't matter.
Let's try sin(kvt)*sin(ωt) which simplifies to
sin(δt)*sin(ωt)
Now we only have two variables.
If sin(δt+δj)*sin(ωt+ωj) = sin(δt)*sin(ωt)
Then j should be equal to nT, where n is an integer and T is a constant based on δ and ω. The period of the wave.
The value of a just affects the relative phase between the two sinusoids.
What I suggested with the breakdown was that you treat the sin(wt) as the amplitude of the sin(k(x+vt)) traveling wave. What is happening?
Since you are only looking at the oscillations at one point in space, you are just multiplying sine waves together like you've shown: sin(δt)*sin(ωt) $$y(t)=\sin\delta t \sin\omega t$$ ... basically.
What sort of shape is that wave?
Do you know about beats?
Do you know about amplitude modulation?
If δ and ω are both integers, then j = n*2∏
I don't know much about AM, but I do know that
is a form of AM
You should google the key words - "beats" as well.
The resulting waveform is not a simple sinusoid - so you have to figure out how the concept of a period applies here. What is correct depends on what you need the period for. How does this question come up?
i.e. If you need the time before the pattern starts to repeat, then the phase factor will be important too.
You should experiment by plotting the waves for different values of the parameters and see how it works.
FAQ: Finding the period of a sinusoid
What is a sinusoid?
A sinusoid is a mathematical function that describes a smooth repetitive oscillation. It is commonly represented by the formula y = A sin (ωt + φ), where A is the amplitude, ω is the angular frequency, and φ is the phase angle.
How do you find the period of a sinusoid?
The period of a sinusoid is the amount of time it takes for one complete cycle of the oscillation. It can be found by determining the distance between two consecutive peaks or troughs of the graph, or by dividing the angular frequency (ω) by 2π. The formula for period is T = 2π/ω.
What are the units for period?
The units for period depend on the units of the angular frequency (ω). If ω is given in radians per second, then the period will be in seconds. If ω is given in cycles per second (Hz), then the period will be in seconds as well.
What is the relationship between period and frequency?
Period and frequency are inversely related. This means that as the period increases, the frequency decreases, and vice versa. The formula for frequency is f = 1/T, where T is the period. This relationship can also be seen in the graph of a sinusoid, as a longer period corresponds to a wider, flatter graph, while a shorter period corresponds to a narrower, steeper graph.
How do you use a graph to find the period of a sinusoid?
To find the period of a sinusoid using a graph, you can identify two consecutive peaks or troughs and measure the distance between them. This distance represents one complete cycle, or the period. Alternatively, you can use the formula T = 2π/ω, where ω is the angular frequency, to calculate the period based on the graph.
