Finding the Point of Intersection: Is (-2, -2.5) the Solution?
In summary, the point of intersection of the two lines is (-2, -2.5) and it can be found by solving simultaneous equations.
nicholar1
Hi,
I am looking for some help on how you find the point of intersection of the following two lines:
4y = x - 8
2y = 3x + 1
Thanks for any help.
/Nichola
Mathematics news on Phys.org
nicholar1 said:
Hi,
4y = x - 8
2y = 3x + 1
/Nichola
Hi Nichola
The intersection will be at the point where the equations are equal. Are you familiar with solving simultaneous equations either by substitution or elimination?
Multiply the second equation by 2:
\(\displaystyle 4y = 6x+2\)
You can then subtract this equation from the first one to eliminate y
SuperSonic4 said:
Hi Nichola
Hi,
No I have never done simultaneous equations before, that's where I'm getting confused, how they work together.
nicholar1 said:
Hi,
4y = x - 8
2y = 3x + 1
/Nichola
nicholar1 said:
Hi,
Welcome to MHB Nichola! :)
We can multiply the second equation by 2 as Supersonic suggested.
That is, we start with:
$$2y = 3x + 1$$
and we end up with
$$4y = 6x + 2$$
Now we can see that according to the first equation $4y=x-8$ and according to the rewritten second equation we also have that $4y=6x+2$.
Since both are equal to $4y$ it must be that $x-8$ is equal to $6x+2$.
How would you solve the equation $x-8 = 6x+2$?
$$2y = 3x + 1$$
and we end up with
$$4y = 6x + 2$$
So to solve the equation $x-8 = 6x+2$ we:
Add 8 to both sides: $x = 6x+10$
Subtract 6x from both sides: $-5x = 10$
Divide both sides by -5: $x = -2$
So, substituting x = -2 into the equations give:
$4y = -2 - 8 = -10$
$2y = 3 x (-2) + 1 = -5$
So dividing -10 by 4 or -5 by 2 gives -2.5.
So does that mean the point of intersection is (-2, -2.5)?
Thanks for the help guys :)
/Nichola
$4y = -2 - 8 = -10$
/Nichola
Let's verify...
Substiting (-2, -2.5) in:
\begin{aligned}4y &= x - 8 \\
2y &= 3x + 1
\end{aligned}
gives:
\begin{aligned}4 \cdot -2.5 &= -2 -8 \\
2 \cdot -2.5 &= 3 \cdot -2 + 1
\end{aligned}
simplifying:
\begin{aligned}-10 &= -10 \\
-5 &= -5
\end{aligned}
We have a match, so this is the correct solution! (Happy)
FAQ: Finding the Point of Intersection: Is (-2, -2.5) the Solution?
What is a point of intersection?
A point of intersection is a specific location where two or more lines, curves, or shapes intersect. It is the common point shared by all of the intersecting objects.
How do you find the point of intersection between two lines?
The point of intersection between two lines can be found by solving the equations of the lines simultaneously. This can be done by using substitution, elimination, or graphing methods.
Can there be more than one point of intersection between two lines?
Yes, there can be more than one point of intersection between two lines. This occurs when the two lines are parallel or coincident.
What is the significance of a point of intersection in mathematics?
In mathematics, a point of intersection is significant because it represents a solution to a system of equations. It is also used to find the coordinates of a common point on a graph or to determine the intersection of two geometric shapes.
How is the point of intersection used in real-world applications?
The point of intersection is used in many real-world applications, such as navigation, engineering, and economics. It can be used to determine where two roads or paths cross, where two pipes intersect, or where two supply and demand curves intersect.
