fauboca
- 158
How do I find the power series for [itex]z^7[/itex]?
I can't remember.
I can't remember.
fauboca said:How do I find the power series for [itex]z^7[/itex]?
I can't remember.
Dick said:If you mean the power series expansion around a point that's not 0, say around z=1, then write z^7=((z-1)+1)^7 and expand that.
fauboca said:Around zero. I have been looking through Rudin and Rosenlicht but I don't see an example of what I am looking for.
Dick said:Then what are you looking for? z^7 IS the power series for the function f(z)=z^7 around z=0.
fauboca said:$$
f(z) = \frac{1}{2\pi i}\sum_{n = 0}^{\infty}\left[\int_0^{2\pi}\frac{u^7}{u^{n + 1}}du z^n\right] = z^7.
I want to show the above equality. I know since u^7 is analytic in the unit disk, g will be the same as f. But is there a way to show that without stating this?
Dick said:Well, the integral is zero unless n=7, isn't it? The integral of u^k is zero unless k=(-1).
fauboca said:For all z inside of C (C the unit circle oriented counterclockwise),
[tex]
f(z) = \frac{1}{2\pi i}\int_C \frac{g(u)}{u-z} du
[/tex]
where [itex]g(u) = \bar{u}[/itex] is a continuous function and [itex]f[/itex] is analytic in C. Describe [itex]f[/itex]in C in terms of a power series.
[itex]\displaystyle f(z) = \frac{1}{2\pi i}\int_C \frac{\bar{u}}{u-z} du[/itex] I am confused with what I am supposed to do. I know it says describe [itex]f[/itex] in terms of a power series.
Dick said:[itex]\int_C \frac{u^7}{u^{n + 1}}du=\int_C u^{7 - n - 1}du[/itex]. That's zero unless the exponent is -1 which happens when n=7.
fauboca said:Ok so if the function was 1/u, we would have u^{-n-2}. This one would always be 0 then?
Dick said:Sure, but f(u)=1/u doesn't have a power series expansion around 0 with only positive powers. You'd need a Laurent series instead of a power series to represent it.
fauboca said:If we haven't done Laurent Series yet, how should I handle it then?
Dick said:You don't. f(z)=1/z doesn't have a power series expansion around z=0. f(z) has to be analytic at z=0 to have a power series expansion. 1/z isn't analytic at z=0.
fauboca said:Evaluating the sum and the integral for it yields f(z) = 0. Is that correct to put down after evaluating f(z) since all the terms are 0?
Dick said:All of the terms in your series are zero, yes. But that still doesn't make f(z)=1/z=0. I'm not sure you are paying attention here.
fauboca said:I understand what you are saying but I am trying to solve for
f(z) = \frac{1}{2\pi i}\sum_{n = 0}^{\infty}\left[\int_0^{2\pi}\frac{\frac{1}{u}}{u^{n + 1}}du z^n\right].
Since Laurent series are out and all the terms are 0, what else could f(z) be?
Dick said:I am trying to tell you that the series you are quoting is NOT valid for all functions f(z). f(z) has to be analytic at z=0 to apply that. f(z)=1/z is NOT analytic at z=0. I've already told you this.
fauboca said:By the integral transform theorem, if you put a continuous function g(u) into f(z), you get out an analytic function. If g is analytic, you get the same function. So f(z) has to equal something.
Dick said:I'm not quite sure why this is so difficult. 1/u is continuous on the contour. And yes, you get an analytic function out. It's f(z)=0. Now you say "If g is analytic, you get the same function.". g(u)=1/u ISN'T analytic at u=0. So the function you get out f(z)=0, ISN'T the same as the function you put in f(z)=1/z.
fauboca said:I understand that. I was verifying that f(z) = 0 is correct. You kept saying you don't understand what I telling you.
Dick said:Apologies if I'm misunderstanding. But I'm just saying 0 isn't the power series representation of 1/z because it doesn't have one. And f(z)=1/z is not equal to 0. That's all. So, ok. Yes f(z)=0. I somehow thought you were trying to represent 1/z as a power series. Sorry.
fauboca said:No problem. I know f(z) = 1/z\neq 0 but when I said f(z) I meant,
A trivial power series is a function in the form of f(x) = c, where c is a constant. This means that the function does not depend on x and remains the same for all values of x.
A regular power series is a function in the form of f(x) = a0 + a1x + a2x2 + a3x3 + ... , where a0, a1, a2, ... are constants and the exponent of x increases by 1 in each term. In contrast, a trivial power series has all terms with an exponent of 0, making it a constant function.
Trivial power series may seem simple, but they play an important role in understanding power series as a whole. They serve as a basic building block for more complex power series and can be used to create new and interesting functions.
Yes, a trivial power series can be differentiated and integrated, just like any other power series. However, since all terms have an exponent of 0, the derivative will always be 0 and the integral will simply be c0x + k, where k is a constant of integration.
Trivial power series are often used in physics and engineering to model simple systems. They can also be used in computer science and programming to create basic functions and algorithms. Additionally, understanding trivial power series can help build a foundation for understanding more complex mathematical concepts.
