Finding the prob. in a continuous uniform distribution (z values)
In summary, the student is trying to solve a problem with a uniform distribution but is having difficulty understanding what the mean and variance are. Without knowing those values, he is at a loss for how to proceed.
rogo0034
37
I understand that all i need to do is plug these two points into the formula and subtract to get the correct area, but i am not provided a mean or variance as i normally am, so I'm at a loss.
What does that formula for Z have to do with the original question? Do you know what the definition of a uniform distribution is (i.e. can you write down the density function)
Here's what we are given in one of the examples helping to explain it to us.
I put in the formula for Z because if i had the standard deviation and mean, this would be extremely simple (for me)
Office_Shredders gentle question is a hint that the normal distribution has nothing to do with the problem. Try answering the questions he posed.
In addition to this, since the distribution in question is uniform, I suggest to draw a picture :-) In this case it would be very self-explanatory.
OK, so this isn't helping yet, I'm still under the impression that in order to solve this problem, i need the mean (which I'm assuming is 3), and the standard deviation from the mean (which I'm at a loss for). Anyone able to help explain this better, it's the first question in my homework and i feel I'm just over thinking it?
Why are you assuming the mean is 3? Don't you know how to calculate the mean?
1. What is the density function for this problem?
2. What is the formula for the mean? Does it give 3?
3. What is the formula for variance? What does it give?
Show us some work. And, as an aside, are you sure calculating the mean and variance is what you need for this problem? What is the formula for P(A|B)?
I'm assuming the mean is 3 because it is a uniform distribution 1 through 5, which would make the mean three... right? (two units on each side, central tendency). I don't have any more information about this problem than is given, but since it is a normal uniform distribution, it should fit into this distribution:
I don't have formulas for the mean or variance, alls i have a proofs that the expected value of (x) is the mean, and the expected value of (x minus the mean squared) is the SD.
Great, i finished the sections homework without any issues, took no time at all, except for this one problem, I must be over thinking it...?? this problem seems like it should be so simple.
Yes, it would be simple if you would just answer the questions I and others have asked. Why do you keep mentioning the normal distribution, even after you have acknowledged it is a uniform distribution?
Among other suggestions, I have highlighted in dark blue two questions you have ignored. Answering those two questions is necessary to proceed. And to answer what the density function is, I mean a formula.
ahhhh, for some reason i was thinking this was a bell curve the whole time. But, because of that realization, i found the formulas for mean and SD, and plugged them into the formula originally given. Sorry the quality is terrible, but here's what i got.
You keep going back to thurs formula for normal distributions, but you don't have a normal distribution.
I think maybe a more basic question is in order: what's the definition of a density function?
And he still hasn't give the formula f(x) for the density or the formula for P(A|B). Rogo0034 if you can't answer those two questions you need more help than I can give you. I'm sure they are in your textbook.
Do you know what a uniform probability distribution is?
Related to Finding the prob. in a continuous uniform distribution (z values)
1. What is a continuous uniform distribution?
A continuous uniform distribution is a probability distribution where all values within a specific range have an equal chance of occurring. This means that the probability of any value occurring within the range is the same.
2. How do you calculate the probability in a continuous uniform distribution?
To calculate the probability in a continuous uniform distribution, we use the formula P(x < a) = (a-b)/(b-a), where a and b are the lower and upper limits of the distribution. This formula can also be used to find the probability of a specific range of values within the distribution.
3. What is the role of z values in a continuous uniform distribution?
Z values, also known as standard scores, are used to standardize the distribution and allow for comparison between different distributions. In a continuous uniform distribution, z values are used to calculate the probability of a specific value or range of values.
4. How do you find the z value in a continuous uniform distribution?
The z value in a continuous uniform distribution can be found by subtracting the mean of the distribution from the desired value and then dividing by the standard deviation. The resulting value is the z value.
5. Can the probability be greater than 1 in a continuous uniform distribution?
No, the probability in a continuous uniform distribution cannot be greater than 1. This is because the total area under the curve must equal 1, representing the total probability of all values within the distribution.
12K
