MHB Finding the projection of a vector.
  • Thread starter Thread starter Jundoe
    Projection Vector
The discussion focuses on finding the projection of a vector v onto a line L defined by parametric equations. The user initially struggles with identifying the correct vector to use for L, having derived two vectors from the equations. It is clarified that the direction vector of L should be used for w1, while the position vector is not relevant for this calculation. The user successfully recalculates w1 and w2 based on this understanding, confirming their approach is correct. The conversation concludes with a reference to a complete solution for further clarification.
Jundoe
I would like to verify this problem from an introductory to Linear Algebra course.
It goes as follows:
Let L be the line with parametric equations x=2+3t, y=1-2t, z=-2+t, and let v=(3,2,2). Find vectors w1 and w2 such that v=w1+w2, and such that w1 is parallel to L and w2 is perpendicular to L.
This is how I proceeded:
From the given parametric equations I constructed the vectors:
line L: a=(3, -2, 1) and b=(2,1,-2).
To find w1, I know that w1= kL
And to find k: (v.L)/||L||2
And w2 is just a matter of: w2=v-w1
The issue I am facing is, which vector do I chose for the L?
I have found 2 vectors from the parametric equations.
Should I simply take the difference? a-b= (1,-3,3)?
Thank You.
[edit.]
If I stick to my L line being equal to (1,-3,3), due to the fact that b is my position vector, then:
w1 = 3/19(1,-3,3)
w2 = (3,2,2) - 3/19(1,-3,3)
Am I completely off?
It goes as follows:
Let L be the line with parametric equations x=2+3t, y=1-2t, z=-2+t, and let v=(3,2,2). Find vectors w1 and w2 such that v=w1+w2, and such that w1 is parallel to L andw2 is perpendicular to L.
Thank You.
Hi Jundoe, and welcome to MHB!
You have got the equation of the line L as $(x,y,z) = \mathbf{b} + \mathbf{a}t.$ In that equation, $\mathbf{b}$ (the constant) is a point on the line, and $\mathbf{a}$ (the coefficient of $t$) gives the direction of the line. So you want to take $\mathbf{a}$ as the parameter for $\mathbf{w}_1$, because you want $\mathbf{w}_1$ to point in the same direction as L.
Thank you for replying! So in other words, the position of the vector–its origin–is irrelevant in this matter?
So, ignoring the point. I would have the following:
w1= 1/2(3,-2,1)
w2= (3,2,2)-1/2(3,-2,1)= (3/2, 3, 3/2)
Hope I didn't do any careless mistakes, does that seem about right?
w1= 1/2(3,-2,1)
Correct! (Yes)
