Finding the Range of a Trigonometric Function
In summary, the conversation discusses finding the range of a trigonometric function, specifically y=5cos(x)+3. The method used involves using the fact that the cosine function varies from -1 to 1 and then multiplying through by the given amplitude and adding the given vertical displacement. The resulting range is demonstrated to be between -2 and 8. The conversation also includes a thank you to the teacher for their help.
melissax
Hello, I have some questions and i couldn't solve them can you help me?
If y=5cos(x)+3 then what is the heap of ?
(a) All real numbers
(b) alpha<= y <= alpha
(c) -2 <= y <= 10
( d)-2 <= y <= 8 What is the solution?
Thank you.
Mathematics news on Phys.org
re: Finding the Range of a Trignometric Function
To find the range of the given sinusoid, I would use this method:
$\displaystyle -1\le\cos(x)\le1$
$\displaystyle -A\le A\cos(x)\le A$
$\displaystyle B-A\le A\cos(x)+B\le B+A$
Can you apply this procedure to the function you are given?
Thank you very much
You showed me path, i will apply.
-1<=5*Cos(x)+3<=1
-5<=5*Cos(x)+3<=5
-5-3<=5Cos(x)<=5-3
-8<=5Cos(x)<=2
As i understand between -2 and 8 but how i can show?
You have found the correct range, but what you actually want to do is this:
Begin with the fact that the cosine function varies from -1 to 1:
Multiply through by the given amplitude of 5:
$\displaystyle -5\le 5\cos(x)\le5$
Add through by the given vertical displacement of 3:
$\displaystyle 3-5\le 5\cos(x)+3\le3+5$
Simplify:
$\displaystyle -2\le 5\cos(x)+3\le8$
And this demonstrates the range is [-2,8].
I am sory. You showed me path but i wrote wrong.
When i solved second then i saw?
Thank you. You are great teacher.
Glad to help out, and welcome to the forum!:)
FAQ: Finding the Range of a Trigonometric Function
What is the definition of the range of a trigonometric function?
The range of a trigonometric function refers to the set of all possible output values or y-values that the function can produce for any given input or x-value.
How can I find the range of a sine or cosine function?
The range of a sine or cosine function can be found by looking at the amplitude, or the maximum and minimum values, of the function. The range will be all values between the negative and positive amplitude values.
Is it possible for the range of a trigonometric function to be infinite?
Yes, it is possible for the range of a trigonometric function to be infinite. This can occur when the function has no upper or lower limit, such as in the case of a tangent function.
Can trigonometric functions have a restricted range?
Yes, trigonometric functions can have a restricted range. This can occur when the function is limited by a specific domain or when certain restrictions are placed on the input values.
How does the period of a trigonometric function affect its range?
The period of a trigonometric function, which is the distance between two consecutive peaks or troughs, can affect its range by limiting the number of possible output values. For example, a function with a smaller period will have a smaller range compared to a function with a larger period.
