Finding the Range of the given function
In summary: However, when you add the constant 2 to the equation, it shifts the minimum value up to 8. The AM >= GM inequality only tells you that the arithmetic mean is greater than or equal to the geometric mean, but it does not tell you the exact values of either. In this case, the AM is 8 and the GM is 6, so the minimum value is somewhere in between.
Kaushik
282
Find the range of ##f(x) = 6^x + 3^x + 6^{-x} + 3^{-x} + 2##
AM >= GM
But, ## AM >= GM##
So,
##f(x) >= 5 * 2 ^ {\frac{1}{5}}##
But this is not the case. According to the graph, it is ## f(x) >= 6##.
If I do the same thing without considering the constant '2' then I am getting the answer.
let ##g(x) = 6^x + 3^x + 6^{-x} + 3^{-x} ## and ##f(x) = g(x) + 2##
Using ##AM>=GM##,
##g(x) >= 4##
Hence, ##f(x) >= 6##
Why is this the case? Why is the latter approach working but no the former?
Kaushik said:
Homework Statement:: Find the range of ##f(x) = 6^x + 3^x + 6^{-x} + 3^{-x} + 2##
Relevant Equations:: AM >= GM
Kaushik said:
But, ## AM >= GM##
So,
I don't see what AM >= GM has to do with this problem, or how the inequality you show is related to this problem. Certainly ##f(x) \ge 5 \cdot 2^{1/5}##, but that's a very rough lower bound.
Using ##AM>=GM##,
##g(x) >= 4##
##6^x + 6^{-x}## has a minimum value of 2 for x = 0. Likewise, ##3^x + 3^{-x}## also has a minimum value of 2 at x = 0. Add these pairs together + 2, and you get a minimum value of 6.
Likes nomadreid, Kaushik and SammyS
Related to Finding the Range of the given function
1. What is the definition of the range of a function?
The range of a function is the set of all possible output values that the function can produce.
2. How do you find the range of a given function?
To find the range of a function, you need to evaluate the function for different input values and record the corresponding output values. The set of all these output values is the range of the function.
3. Can the range of a function be empty?
Yes, the range of a function can be empty if the function has no output values for any input value. This can happen when the function is undefined for certain input values.
4. Is the range of a function always a continuous set of numbers?
No, the range of a function can also be a discrete set of numbers, depending on the nature of the function. For example, the range of a function that only outputs integers will be a discrete set of numbers.
5. Can the range of a function be infinite?
Yes, the range of a function can be infinite if the function has an infinite number of possible output values. This can happen when the function is a trigonometric or exponential function.
