MHB Finding the Rate of Change of Water Level in a Filling Trough
bkbowser
I am assuming that I am setting this up incorrectly or substituting the incorrect values.
A water trough is 10 m long and a cross-section has the shape
of an isosceles trapezoid that is 30 cm wide at the bottom,
80 cm wide at the top, and has height 50 cm. If the trough is
being filled with water at the rate of 0.2 m^3͞/min, how fast is the
water level rising when the water is 30 cm deep?
I broke up the trapezoid into 2 triangles and a rectangle so the area should be
A = 2*Triangle + Rectangle
A = (b*h)+(50*h)
I can look at b in terms of h by using similar triangles. Each triangle has side a, of 25 side b, of 50. So the triangle formed by the water level must be side a 15 side b of 30. So b is h/2
A = (h^2*1/2) + (50*h)
Converting this into volume should be easy, just multiply the equation A, by 1000.
dA/dt = 2/2*h*dh/dt + 50*dh/dt
Convert dA/dt into dV/dt;
1000*dA/dt = dh/dt(h+50)*1000
Since 1000*dA/dt I can make a substitution
dV/dt = dh/dt(h+50)*1000
I have a book answer of 10/3. Could someone be so kind as to point out the errors? Thanks!
It might be a good idea to double-check your formula for the area of the trapezoid in terms of h. It should yield the area of the whole trapezoid when h = 50. Does it?
(80+50)/2*50=3250
versus
25*50+30*50=2750
so no they are not the same. i can't think of any particular reason why they are not equal though. and there's the added difficulty of it gumming the whole rest of the problem up :(
A = (b*h)+(50*h)
You are told the the height of the trapezoid is 50 cm so why are you multiplying h by 50? The base of the trapezoid is 30 cm wide so the area of the central square is 30h, not 50h.
For original Zeta function, ζ(s)=1+1/2^s+1/3^s+1/4^s+... =1+e^(-slog2)+e^(-slog3)+e^(-slog4)+... , Re(s)>1 Riemann extended the Zeta function to the region where s≠1 using analytical extension. New Zeta function is in the form of contour integration, which appears simple but is actually more inconvenient to analyze than the original Zeta function. The original Zeta function already contains all the information about the distribution of prime numbers. So we only handle with original Zeta...
