Finding the resultant couple moment
In summary, the conversation discusses the correct method for calculating the moment produced by two equal but opposite forces. The method involves finding the distance between the lines of application of the forces, rather than the distance between the points of application. The summary also includes the resulting formula for calculating the moment and mentions the use of Pythagoras to solve for the distances between each couple.
theBEAST
364
I attached the question as a picture to this thread
M=Fd
I was taught that the moment produced by two equal but opposite forces is the magnitude of one force multiplied by the distance between the two forces.
I used Pythagoras to solve for the distances between each of the couples and found sqrt32 and sqrt8 to be these distances.
Thus
M1= 150*sqrt32
M2=200*sqrt8
and the resultant moment
=M1-M2
=283Nm [clockwise]
This is not the answer, the method the answer key used was breaking up the couples into x and y. I don't understand why my method does not work as well.
hi theBEAST! :smile:
theBEAST said:
… the distances between each of the couples and found sqrt32 and sqrt8 to be these distances.
nooo :redface:
√32 and √8 are the distances between the points of application of these forces
the couple uses the distance between the lines of application of the forces :wink:
Related to Finding the resultant couple moment
What is a resultant couple moment?
A resultant couple moment is a measure of the combined rotational force on an object caused by a pair of equal and opposite forces acting on different points along the object's axis. It is represented by a vector perpendicular to the plane of the couple and its magnitude is equal to the product of one of the forces and the distance between them.
How do you calculate the resultant couple moment?
The resultant couple moment can be calculated by multiplying one of the forces by the distance between them and taking the cross product with the unit vector perpendicular to the plane of the couple. This can be represented mathematically as M = F x d, where M is the resultant couple moment, F is one of the forces, and d is the distance between the forces.
What is the difference between a resultant couple moment and a resultant force?
A resultant couple moment is a measure of the combined rotational force acting on an object, while a resultant force is a measure of the combined translational force acting on an object. While both represent the combined effect of multiple forces, they act in different ways and have different equations for calculation.
Why is it important to find the resultant couple moment?
Finding the resultant couple moment is important in understanding the overall forces acting on an object and predicting its rotational behavior. It is particularly useful in engineering and physics applications, where precise calculations of forces and motion are necessary for designing and analyzing structures and systems.
Can the resultant couple moment be zero?
Yes, the resultant couple moment can be zero if the forces acting on the object are equal in magnitude and are applied at the same point on the axis. This means that the object will not experience any rotational force and will remain in equilibrium. However, this is not always the case and the resultant couple moment can be non-zero, leading to rotational motion.
