Finding the Right String Length for a Dropping Mass
In summary, a group has been tasked with choosing a string length that will allow a mass, attached to two springs and the string and dropped from a height of 4.29 meters, to fall within 25 cm of the ground. The group will be given the mass on the day of the drop and must calculate the correct string length within ten minutes before the drop. The only variable that can be changed is the length of the string. The group has taken data on both combinations of the two springs and calculated their spring constants. The group is considering the conservation of energy and the equation -½ k x² + m g (h + x) = 0 as a possible solution.
Masaharustin
My group and I have been tasked with choosing a string length so that a mass attached to two springs and the string, dropped from 4.29 meters, will fall within 25 cm of the ground. On the day of the drop we will be given the mass. We will use two springs that we already have and within ten minutes before the drop, must calculate the correct string length.
Constants:
Mass
drop height
the two springs (although the order in which they are used can be changed, we have taken data on both combinations)
*The only thing we can change is the length of the string from which the two springs and mass are hanging.
Hooke's Law: k= mg/x
x = √(2U/k) * U is the spring's potential energy
u = .5kx^2
The data we have taken so far as well as the calculated spring constants are in this google document.
https://docs.google.com/spreadsheet/ccc?key=0AlOf8KvTeCTrdHBxaldGXzB6WWo5RXVSbTAzTmt5VUE
With the information we have now we can predict the stretch of a stationary spring. However, we cannot figure out how to predict the stretch when taking into account the force generated by the mass' fall from 4.29 m.
We would very much appreciate it if someone could simply point us in the right direction on how to go about this, we've kind of been thrown in the deep end. Thanks.
What conserved quantities are there going to be?
Sorry what do you mean by conserved quantities?
Thanks for the reply.
The quantities which are not lost in the system
This is a high school assignment, so I think [hope] we're not dealing with lost quantities.
EDIT: We made headway on the problem, air resistance is negligible. Are we correct in thinking that this equation applies?
ΔE = 0
ΔE = 0
Conservation of energy should apply to a good approximation, at least for the first "bounce" and before much energy can be lost to heat through mechanical flexing of the springs.
Can you describe the precise setup for the "bungee" trial in more detail? It looks like you've got two different springs that are to be attached in series. When will you get to know the order of their attachment?
When you measured your spring displacements, were they 'end to end' measurements (attachment point to attachment point)? Did they include allowances for whatever means is required to connect them end to end, to loads, or to fixed attachment points?
Where will the added string be attached? At the top of the springs or at the bottom between the last spring and the load mass?
How exactly is the drop to be performed? Will the load mass be dropped from the height of the fixed top spring attachment with the springs initially unloaded, or in some other fashion?
How will you include the mass of the springs themselves in the calculations?
Related to Finding the Right String Length for a Dropping Mass
1. What is the purpose of finding the right string length for a dropping mass?
The purpose of finding the right string length for a dropping mass is to determine the optimal length at which a mass should be dropped in order to produce the desired outcome or result. This is important in experiments and studies that involve the use of a dropping mass, as the length of the string can greatly impact the data and conclusions drawn from the experiment.
2. How is the string length determined for a dropping mass experiment?
The string length for a dropping mass experiment is typically determined through trial and error. The length is gradually increased or decreased until the desired outcome is achieved. This process may also involve making calculations based on the mass, gravity, and desired result.
3. What factors should be considered when determining the string length for a dropping mass experiment?
When determining the string length for a dropping mass experiment, factors such as the mass of the object, the desired outcome or result, and the force of gravity should be taken into consideration. Other factors, such as air resistance, may also be relevant depending on the specific experiment.
4. How does the string length affect the outcome of a dropping mass experiment?
The string length can greatly impact the outcome of a dropping mass experiment. A shorter string may result in a quicker and more forceful impact, while a longer string may result in a slower and less forceful impact. The length can also affect the trajectory and angle at which the mass falls, which can impact the data and conclusions drawn from the experiment.
5. Are there any limitations to the string length in a dropping mass experiment?
There may be limitations to the string length in a dropping mass experiment, depending on the specific experiment and its objectives. For example, if the experiment is being conducted in a confined space, there may be a maximum length that can be used. Additionally, the strength and stability of the string should also be considered to ensure that it can support the weight of the mass being dropped.
