Finding the shared area of 2 polar equations
In summary, to find the area of the region common to the two given polar equations, r=5-3cos(θ) and r=5-2sin(θ), we must equate the equations and solve for the limits of integration. The resulting values of theta are π/4 and 5π/4. The integral for finding the shared area would be A = ∫(5−3cos(θ))^2 dθ + ∫(5−2sin(θ))^2 dθ.
shortman12012
Given the two polar equations r=5-3cos(θ) and r=5-2sin(θ) find the area of the region common to both curves.
A= 1/2∫ r^2 dθ
i understand that i plug in the two equations into the equation, but i don't know how to find the limits of integration.
To find the limits of the integral, equate the equations, so set:
[tex]
5-3\cos\theta =5-2\sin\theta
[/tex]
This will give two values of theta for your limits.
correction it should be 5-3cosθ =5-3sinθ, but after equating those two and solving i got
θ=π/4,5π/4
so now would the correct integral for solving the shared area of the two limaçon
A = ∫(5−3cos(θ))^2 dθ + ∫(5−2sin(θ))^2 dθ ?
Related to Finding the shared area of 2 polar equations
1. What are polar equations?
Polar equations are mathematical expressions that describe a curve or shape in a polar coordinate system. They involve a variable radius and angle, rather than x and y coordinates.
2. How do you find the shared area of 2 polar equations?
To find the shared area of 2 polar equations, you need to graph both equations on the same polar coordinate plane. Then, find the points where the curves intersect and use the formula for finding the area between 2 polar curves, which is A = 1/2∫[r1^2-r2^2]dθ, where r1 and r2 are the radii of the curves at each point of intersection.
3. What is the difference between rectangular and polar equations?
Rectangular equations use x and y coordinates to graph a curve or shape, while polar equations use a variable radius and angle. Rectangular equations are more commonly used in traditional algebraic graphing, while polar equations are often used in physics and engineering to describe circular or rotational motion.
4. Can polar equations be converted to rectangular equations?
Yes, polar equations can be converted to rectangular equations and vice versa. This can be done by using the formulas x = rcosθ and y = rsinθ to convert from polar to rectangular, and x^2 + y^2 = r^2 to convert from rectangular to polar.
5. What are some real-world applications of polar equations?
Polar equations have many real-world applications, such as in physics for describing rotational motion, in engineering for designing circular structures, and in astronomy for mapping the positions of celestial objects. They are also used in computer graphics to create 3D shapes and animations.
