Finding the Solution to a Differential Equation with Reciprocal Relationship
  • MHB
  • Thread starter karush
  • Tags
    Reciprocal
In summary, the given differential equation can be solved by first substituting $u=e^y$ to obtain a linear equation in $x$ and then using an integrating factor to solve for $x$. The final solution can be written as $x=ce^{-y}+\frac{1}{2}e^y$, where $c$ is a constant.
karush
MHB
3,269
$\textsf{Find the solution of:}$
$\displaystyle\frac{dy}{dx}=\frac{1}{e^y-x}$
ok i kinda don't know what the first step is
was going to multiply both sides by the denominator but
I would begin here with the substitution:
\(\displaystyle u=e^y\implies u'=uy'\)
And so the ODE becomes:
\(\displaystyle \frac{1}{u}u'=\frac{1}{u-x}\)
Or:
\(\displaystyle x'+\frac{1}{u}x=1\)
Now you have a linear equation in $x$...can you proceed?
We could also simply state:
\(\displaystyle \d{x}{y}=e^y-x\)
\(\displaystyle \d{x}{y}+x=e^y\)
Now, our integrating factor is:
\(\displaystyle \mu(y)=\exp\left(\int\,dy\right)=e^y\)
And we then obtain:
\(\displaystyle \frac{d}{dy}\left(e^yx\right)=e^{2y}\)
Integrate w.r.t $y$:
\(\displaystyle e^yx=\frac{1}{2}e^{2y}+c_1\)
Now, we have a quadratic in $e^y$ which cay be written in standard form as:
\(\displaystyle e^{2y}-2xe^{y}-c_2=0\) ($c_2=-2c_1$)
Applying the quadratic formula, we get:
\(\displaystyle e^y=\frac{2x\pm\sqrt{4x^2+4c_2}}{2}=x\pm\sqrt{x^2+c_2}\)
And this implies:
\(\displaystyle y(x)=\ln\left|x\pm\sqrt{x^2+c_2}\right|\)
And we then obtain:
$\textsf{ok the book answer was}$
$$x=ce^{-y}+\frac{1}{2}e^y$$
$\textsf{which would be derived from}$
$\textsf{by dividing thru by $e^y$}$
That's fine giving $x$ as a function of $y$...I just chose to give $y$ as a function of $x$ since the original equation has $x$ as the independent variable. :)
FAQ: Finding the Solution to a Differential Equation with Reciprocal Relationship
What is the significance of "2.1.9 de with reciprocal" in science?
2.1.9 de with reciprocal refers to a specific type of chemical reaction known as a reciprocal reaction, where two substances react with each other to form two new products. This type of reaction is important in understanding the dynamics of chemical reactions and can be used to predict the products of a reaction.
How does a reciprocal reaction differ from a regular chemical reaction?
In a regular chemical reaction, two or more substances react to form a single product. In a reciprocal reaction, two substances react with each other to form two new products. This type of reaction is often reversible, meaning the products can react with each other to reform the original reactants.
What are some examples of reciprocal reactions?
One common example of a reciprocal reaction is the reaction between an acid and a base to form a salt and water. Another example is the reaction between hydrogen and oxygen to form water and the reverse reaction of water breaking down into hydrogen and oxygen.
How is the rate of a reciprocal reaction determined?
The rate of a reciprocal reaction can be determined by measuring the concentration of the products and reactants over time. The rate of a reciprocal reaction is often slower than a regular chemical reaction because it involves the formation of two products instead of one.
What are the applications of reciprocal reactions in scientific research?
Reciprocal reactions are important in understanding the kinetics and thermodynamics of chemical reactions. They are also used in many industrial processes, such as the production of fertilizers and pharmaceuticals. In addition, reciprocal reactions play a crucial role in biological systems, such as enzyme-catalyzed reactions.
