What Is the Speed of the Comet at a Different Distance?
In summary: But I do not have the M, so do i have to solve for that first by using another conservation law?No, you don't have to solve for the mass at all. The equation will give you the total mechanical energy, which is a constant for the entire orbit.No, you don't have to solve for the mass at all.
Vanessa Avila
94
Comets travel around the sun in elliptical orbits with large eccentricities. If a comet has speed 2.2×10^4 m/s when at a distance of 2.6×10^11 m from the center of the sun, what is its speed when at a distance of 4.2×10^10 m
L = rp = r(mv)
I thought angular momentum is what I had to use for this one and thought of the two distances as perigee and apogee. I used conservation of momentum to attempt to solve the speed:
rmv = rmv
the m's cancel out
so I am left with r1v1 = r2v2
> 2.6 * 10^11m(2.210^4m/s)=4.2*10^10m(v2)
and I solved for the speed like that and got 136190. But that is wrong.
Angular momentum would be a good approach if the two positions in question were aphelion and perihelion. Then the velocities would be perpendicular to the radii and you could apply conservation of angular momentum in a simple scalar form. But this problem does not say that the given positions are aphelion or perihelion, so there's no knowing what the angular relationship will be between the position and velocity vectors.
What other conservation law might you appeal to instead?
Could conservation of mechanical energy work?
1/2mv2=GmM/r
Yes...
1/2mv2=GmM/r
...But not that way. The KE won't be equal to the PE (except for very specific circumstances that don't arise here).
What's the expression for the total mechanical energy of a body in orbit? Note that you can ignore the mass of the object itself and use what's known as the Specific Mechanical Energy. That's the energy per kg for the body in orbit.
gneill said:
Yes...
Would it be E=-1/2(GmM/r)
That only accounts for the gravitational potential energy (actually half of the GPE). What's missing?
woops.
So is it
E= 1/2mv^2 - GmM/r ?
Vanessa Avila said:
woops.
So is it
Yes, that's the total mechanical energy. As I mentioned previously, you can drop the "m" from the terms and it becomes the Specific Mechanical Energy which works just as well for these problems. You'll find that the "m" would eventually cancel out anyways if keep it.
Okay so then all we have to worry about is gnna be
1/2v^2 - GM/r ?
1/2v^2 - GM/r ?
Yup. That will be the specific mechanical energy, which is a constant for the entire orbit.
So how do i manipulate this to find the missing velocity given two radii and one velocity?
The value that the equation delivers is a constant of the orbit. It applies everywhere along the trajectory.
Think in terms of conservation of energy problems that you've done for objects near the Earth's surface, where you equate initial and final energy sums.
Oh okay so it's going to be like 1/2v^2 - GM/r = 1/2v^2 - GM/r?
Yes, that's the idea.
But I do not have the M, so do i have to solve for that first by using another equation?
Often the gravitational parameter μ = GM is a given value. Your course materials or textbook likely provide a value for it. If not μ then the mass of the Sun should be given.
Likes Vanessa Avila
Thank you so much for the help. I got the right answer finally! :)
I'm glad I could help!
Related to What Is the Speed of the Comet at a Different Distance?
What is a comet's speed?
A comet's speed refers to how fast it is moving through space. It is typically measured in kilometers per second (km/s) or miles per hour (mph).
How is the speed of a comet measured?
The speed of a comet can be measured using a variety of methods, including radar, telescopes, and spacecraft. These methods involve tracking the comet's movement over a certain period of time and using mathematical calculations to determine its speed.
Why is it important to know the speed of a comet?
Knowing the speed of a comet can provide valuable information about its orbit, trajectory, and potential impact with other objects in space. It can also help scientists better understand the composition and behavior of comets.
Can a comet's speed change?
Yes, a comet's speed can change over time as it interacts with other objects in space, such as planets or other comets. Its speed may also change as it gets closer to the sun and experiences the effects of solar radiation and gravity.
How accurate are measurements of a comet's speed?
The accuracy of measurements of a comet's speed can vary depending on the method used and the specific conditions surrounding the comet. However, modern technology and advanced mathematical calculations have made it possible to measure a comet's speed with a high degree of accuracy.
9K
20K
12K
