Finding the Steady State Solution for a RLC circuit
This is better illustrated by looking at the time-constant, ##RC##. When ##t = RC##, ##v_c(t) = V_0 (1 - 1/e)##, which is about 63% of the steady-state value. By the time t = 3RC, the solution is within 5% of the steady-state value.In summary, the conversation was about finding the steady-state solution for a series RLC circuit with an ideal AC voltage source. The solution involved solving a second-order differential equation and finding the particular solution, which represents the steady-state response of the system. The transient solution, which dies off, is also present but only for a short period of time.
Furbishkov
An ideal AC voltage source generating an emf V (t) = V0 cosωt is connected in series with a resistance R, an inductance L, and a capacitance C.
a) Find the steady-state solution for the charge, q(ω,t), which is of the form q0(ω)cos(ωt− δ(ω)).
b) Find the steady-state current in the circuit, I(ω,t).
q0(ω)cos(ωt− δ(ω)).
From Kirchoff's voltage rule ; q = cVocosωt -cLq(double dot) - cRq(single dot)
But I am unsure how to get from there to a steady-state solution with the things I am given. I understand that once I get "a" I will need to derive it to get "b".
q0(ω)cos(ωt− δ(ω)).
I don't think the above is correct. From KVL, you get ##V_R + V_L + V_C = v(t)##, where the left side represents the voltages across the resistor, the inductor, and the capacitor. The right side represents the voltage that is applied to the circuit.
Based on the KVL, the equation becomes
##Ri(t) + L\frac{di(t)}{dt} + \frac 1 C \int_{-\infty}^{\tau = t} i(\tau)d\tau = v(t)##
If you differentiate with respect to t, you get rid of the integral, producing
##R\dot{i} + L\ddot{i} + \frac 1 C i = v'(t)##
This equation can be rearranged and divided through by L, resulting in the following equation.
## \ddot{i} + \frac R L \dot{i} + \frac 1 {LC} i = \frac 1 L v'(t)##
The above is a second order differential equation that can be solved for i(t), from which you can get q(t) by antidifferentiating, since dq/dt = i.
##- cL\ddot{q} - cR\dot{q} + cV_0\cos(\omega t) = q ##
The question now is, do you know how to solve 2nd order differential equations?
Actually, it looks correct if you assume ##c## is the same as ##C##. Rearranging slightly yields
$$L \ddot{q} + R\dot{q} + \frac{1}{C} q = V_0 \cos \omega t,$$ which is KVL applied to the series RLC circuit.
Thanks for the replies. My equation for KVL I wrote,
is the same as yours with some rearranging.
I understand what the steady state represents as a non-transient state of oscillations. But, I am just stuck as to what am I suppose to do to get a steady-state solution from the equation we have above that was obtained from KVL.
As Mark asked you, do you know how to solve a second-order differential equation? That's what you need to do.
I have looked online and understand the general idea of solving a second-order differential equation, but I don't know what I am trying to solve for here and how it relates to the Steady-state equation.
Yet in your previous post, you said
In one breath, you're saying you know how to solve the problem, and in the next, you're saying you don't. It's a bit confusing as to where you're getting stuck.
When you solve a second-order differential equation, the solution will consist of two parts: ##y_h##, the solution to the homogeneous differential equation, and ##y_p##, the particular solution, which represents the response of the system to the forcing function. In physical systems, the homogeneous solution dies off; that is, ##\lim_{t \to \infty} y_h = 0##. Its contribution doesn't persist, i.e., it's transient. The particular solution can stick around as long as the forcing function does. It represents the steady-state response of the system.
For example, suppose you have a step-input to an RC circuit where the capacitor is initially uncharged. KVL would yield the differential equation
$$RC \frac{dv_c}{dt} + v_c = V_0,$$ which has the solution ##v_c(t) = V_0 (1 - e^{-t/RC}).## The constant term in the solution is the steady-state solution while the exponential term, which dies off, is the transient.
FAQ: Finding the Steady State Solution for a RLC circuit
What is a RLC circuit?
A RLC circuit is an electrical circuit that consists of a resistor, inductor, and capacitor. These three components are connected in either series or parallel and create a closed loop for the flow of electricity.
What is the steady state solution for a RLC circuit?
The steady state solution for a RLC circuit is the state in which the voltages and currents in the circuit have reached a constant value and are not changing over time. This occurs when the energy stored in the inductor and capacitor is equal to the energy dissipated by the resistor.
How do you find the steady state solution for a RLC circuit?
To find the steady state solution for a RLC circuit, you can use the equations for the voltage and current in a series RLC circuit, which are V = IR and V = L(di/dt) + Q/C respectively. By setting these equations equal to each other and solving for the current, you can find the steady state current in the circuit.
What factors can affect the steady state solution in a RLC circuit?
The steady state solution in a RLC circuit can be affected by factors such as the resistance, inductance, and capacitance values of the circuit components, as well as the frequency of the input voltage. Additionally, any external disturbances or noise can also affect the steady state solution.
How is the steady state solution useful in real-world applications?
The steady state solution is useful in understanding and analyzing the behavior of RLC circuits in real-world applications. It allows us to determine the behavior of the circuit over time, as well as the amount of energy stored and dissipated in the circuit. This information is crucial in designing and optimizing RLC circuits for different purposes, such as in power transmission systems or electronic devices.
