Finding the string tension and acceleration of a yo-yo.
In summary, the problem involves a yo-yo composed of two disks with a massless string wrapped around a shaft of radius r. The yo-yo descends from release until the string is unwound, and then begins to rewind and climb. The goal is to find the string tension and acceleration of the yo-yo in both descent and ascent, assuming negligible mass of the shaft and a vertical string. The equations used include the inertia tensor, moment of inertia, and angular velocity. However, the problem can be simplified by considering torque and force balance in a plane, resulting in a moment of inertia of two disks rather than one solid cylinder.
Wavefunction
99
A yo-yo of mass [itex]M[/itex] is composed of two disks of radius [itex]R[/itex] separated by a shaft of radius [itex]r[/itex]. A
massless string is would on the shaft, and the loose end is held in the hand. Upon release the
yo-yo descends until the string is unwound. The string the begins to rewind, and the yo-yo
climbs. Find the string tension and acceleration of the yo-yo in descent and ascent. Neglect the
mass of the shaft and assume the shaft radius is sufficiently small so that the string is essentially
vertical.
[itex]J_{ij}=\int_{V}[\rho(r)\delta_{ij}\sum_{k}x_{k}^2-x_ix_j]dV [/itex]
[itex]I_{ij}=J_{ij}-M[\delta_{ij}\sum_{k}a_{k}^2-a_ia_j] [/itex]
[itex]L_i=\sum_{j}I_{ij}\omega_{j}[/itex]
Setup: First I'll define the [itex] x_3 [/itex] axis to be the axis of rotation of the yo-yo. Then [itex]\vec{\omega}[/itex] will have the components [itex]\begin{pmatrix}0\\0\\\omega_{3}\end{pmatrix}[/itex]. Now I need to find [itex]\mathbb{I}[/itex] in order to find [itex]\vec{L}[/itex]. Finally, because I can neglect the mass of the small shaft I will be calculating the inertia tensor of a solid cylinder.
Calculation: Using [itex]J_{ij}=\int_{V}[\rho(r)\delta_{ij}\sum_{k}x_{k}^2-x_ix_j]dV [/itex] I'll find the inertia tensor at the bottom of the cylinder. So I'll need the volume of the region in question:
[itex] 0\leq z\leq a, 0\leq r\leq R, 0\leq \theta\leq 2\pi [/itex]
Case 1) [itex] \delta_{ij}=1 \Rightarrow J_{ii}=\int_{0}^{a}\int_{0}^{2\pi}\int_{0}^{R}[x_1^2+x_2^2+x_3^2-x_i^2]rdrd\theta dz[/itex]
where [itex] x_1 = rcos(\theta), x_2 = rsin(\theta), x_3 =z [/itex]
[itex] i=1; \rightarrow J_{11}=\rho\int_{0}^{a}\int_{0}^{2\pi}\int_{0}^{R}[(rsin(\theta))^2+(z)^2]rdrd\theta dz = \rho\int_{0}^{a}\int_{0}^{2\pi}[\frac{R^4sin^2(\theta)}{4}+\frac{R^2z^2}{2}]d\theta dz = \rho\int_{0}^{a}[\frac{\pi R^4}{4}+2\pi \frac{R^2z^2}{2}]dz [/itex]
[itex]= \rho[\frac{a\pi R^4}{4}+\frac{\pi R^2a^3}{3}] \rightarrow
M\frac{\frac{a\pi R^4}{4}+\frac{\pi R^2a^3}{3}}{a\pi R^2} = \frac{MR^2}{4}+\frac{Ma^2}{3}[/itex]
[itex] i=2; [/itex] the only that changes in this calculation is that [itex] sin(\theta) [/itex] becomes [itex] cos(\theta) [/itex]. Since [itex] \int_{0}^{2\pi}sin^2(\theta)d\theta = \int_{0}^{2\pi}cos^2(\theta)d\theta \Rightarrow J_{11}=J_{22} [/itex]
[itex] i=3; \rightarrow J_{11}=\rho\int_{0}^{a}\int_{0}^{2\pi}\int_{0}^{R}[(r)^2]rdrd\theta dz = \rho\int_{0}^{a}\int_{0}^{2\pi}[\frac{R^4}{4}]d\theta dz = \rho\int_{0}^{a}[2\pi\frac{R^4}{4}]dz [/itex]
[itex] = \rho[\frac{a\pi R^4}{2}] \rightarrow M\frac{\frac{a\pi R^4}{2}}{a\pi R^2} = \frac{MR^2}{2} [/itex]
Case 2)[itex] \delta_{ij}=0 \Rightarrow J_{ij}=\int_{0}^{a}\int_{0}^{2\pi}\int_{0}^{R}[-x_ix_j]rdrd\theta dz[/itex]
[itex] i=1,j=2 \rightarrow \int_{0}^{a}\int_{0}^{2\pi}\int_{0}^{R}[-r^2cos(\theta)sin(\theta)]rdrd\theta dz = \frac{1}{2}\int_{0}^{2\pi}sin(2\theta)d\theta[\int_{0}^{a}\int_{0}^{R}[-r^3]dr dz] = 0 [/itex]
[itex] i=1,j=3 \rightarrow \int_{0}^{a}\int_{0}^{2\pi}\int_{0}^{R}[-rcos(\theta)z]rdrd\theta dz = \int_{0}^{2\pi}cos(\theta)d\theta[\int_{0}^{a}\int_{0}^{R}[-zr^2]dr dz] = 0 [/itex]
[itex]i=2,j=3 \rightarrow \int_{0}^{a}\int_{0}^{2\pi}\int_{0}^{R}[-rsin(\theta)z]rdrd\theta dz = \int_{0}^{2\pi}sin(\theta)d\theta[\int_{0}^{a}\int_{0}^{R}[-zr^2]dr dz] = 0
[/itex]
So [itex] \mathbb{J}=\begin{pmatrix}\frac{MR^2}{4}+\frac{Ma^2}{3}&0&0\\0&\frac{MR^2}{4}+\frac{Ma^2}{3}&0\\0&0&\frac{MR^2}{2}\end{pmatrix}[/itex]
Now I want to find the inertia tensor about the center of mass [itex] \mathbb{I} [/itex]. Using [itex] I_{ij}=J_{ij}-M\delta_{ij}\sum_{k}a_{k}^2-a_ia_j [/itex] where [itex] \vec{a} = \begin{pmatrix}0\\0\\-\frac{a}{2}\end{pmatrix} [/itex]
Case 1) [itex] \delta_{ij}=1 \rightarrow I_{ij}=J_{ij}-M[a_1^2+a_2^2+a_3^2-a_i^2] [/itex]
[itex] i=1; I_{11}=J_{11}-M[a_2^2+a_3^2] \rightarrow I_{11} = \frac{MR^2}{4}+\frac{Ma^2}{3}-M\frac{a^2}{4} = \frac{MR^2}{4}+\frac{Ma^2}{12} = M\frac{3R^2+a^2}{12} [/itex]
[itex] i=2; I_{22} =J_{22}-M[a_1^2+a_3^2] \rightarrow I_{22} = \frac{MR^2}{4}+\frac{Ma^2}{3}-M\frac{a^2}{4} = \frac{MR^2}{4}+\frac{Ma^2}{12} = M\frac{3R^2+a^2}{12} [/itex]
[itex] i=3; I_{33} = J_{33}-M[a_1^2+a_2^2] \rightarrow I_{33}=J_{33} [/itex]
Case 2) [itex] \delta_{ij}=0 \rightarrow I_{ij}=J_{ij}+M[a_ia_j] [/itex] since [itex] j≠i \Rightarrow I_{ij} = J_{ij}[/itex] Since the only non-zero component of [itex]\vec{a}[/itex] is [itex] a_3 [/itex].
Therefore: [itex] \mathbb{I} = \begin{pmatrix}M\frac{3R^2+a^2}{12}&0&0\\0&M\frac{3R^2+a^2}{12}&0\\0&0&\frac{MR^2}{2}\end{pmatrix}[/itex]
Then: [itex] \vec{L}=\mathbb{I}\vec{\omega} \rightarrow \begin{pmatrix}L_1\\L_2\\L_3\end{pmatrix} = \begin{pmatrix}M\frac{3R^2+a^2}{12}&0&0\\0&M\frac{3R^2+a^2}{12}&0\\0&0&\frac{MR^2}{2}\end{pmatrix} \begin{pmatrix}0\\0\\\omega_3\end{pmatrix}[/itex]
Clearly the only non-zero component of [itex] \vec{L} [/itex] is [itex] L_3 = \frac{MR^2}{2}\omega_3 [/itex] So what is [itex] \omega_3 [/itex]? its the angular velocity [itex] \dot{\theta} [/itex] about the [itex] x_3 [/itex] axis so:
[itex] \vec{L} = \begin{pmatrix}0\\0\\\frac{MR^2}{2}\dot{\theta}\end{pmatrix} [/itex]. Also I know that [itex] \vec{\omega} [/itex] is parallel to [itex] \vec{L} [/itex] so [itex] \frac{\partial \vec{L}}{\partial t}_{inertial} =\frac{\partial \vec{L}}{\partial t}_{body}=\vec{\tau} [/itex] And [itex]\dot{\vec{L}} = \begin{pmatrix}0\\0\\\frac{MR^2}{2}\ddot{\theta}\end{pmatrix} = \begin{pmatrix}\tau_1\\\tau_2\\\tau_3\end{pmatrix} [/itex]
At this point I think I should look at the sum of the forces and torques on the yo-yo but I'm not quite sure, and I'd like to make sure the above work is correct before moving forward. Thanks for your help in advance.
I think you may be making this way more complicated than it needs to be. First off, you haven't defined this mysterious 'a' length. If I am understanding this setup correctly, all motion is restricted to a plane, so you don't really have to worry about any tensors. The moment of inertia should just be that of two disks, i.e. I=2(1/2MR^2)=MR^2. All you really need to solve this problem is torque and force balance.
I know it seems i made it more complicated, but I need practice in setting up the more general case i.e dealing with tensors. Oh and the [itex]\vec{a}[/itex] is the vector pointing from the center of mass to the origin of the body-frame coordinates. Oh and a quick question: why is the moment of inertia of two disks instead of one solid cylinder if the thin shaft joining both parts of the yo-yo is massless?
The moment of inertia is that of two disks because, if you neglect the mass of the axle, that's what a yo-yo is made out of: two disks with empty space between them. Also, if that's what 'a' is, then your integrals don't make any sense. The center of mass should be your origin, right between the two disks, so |a|=0. If you really want practice with tensors, do the problem first using simple equations, and then if you must, go back and redo it with tensors.
Okay I see what you're saying about the moment of inertia, but [itex]a[/itex] is the height of the cylinder, but [itex] \vec{a} [/itex] is the vector that points from the center of mass to the origin which is originally at the bottom of the cylinder( I know it was bad notation) I should have called the upper limit in my integral [itex] h [/itex] but the tensor i got is correct.
http://en.wikipedia.org/wiki/List_of_moments_of_inertia
What cylinder? You have two disks. Their moments of inertia depend only the the mass and the radius.
Likes 1 person
I was thinking that the two parts of the yo-yo had thickness but I went back and re-read the problem and it did say disks.
But I could just take the limit as [itex]h[/itex] goes to zero which would give me the inertia tensor for a disk, correct?
As I said before, the moment of inertia of a disk depends only on its mass and its radius.
Related to Finding the string tension and acceleration of a yo-yo.
1. What is string tension and why is it important when using a yo-yo?
String tension refers to the amount of force applied to the string when a yo-yo is in motion. It is important because it affects the yo-yo's speed, stability, and the ability to perform tricks.
2. How can I measure the string tension of a yo-yo?
The string tension of a yo-yo can be measured by using a spring scale. Attach the scale to the string and pull it until the yo-yo is at the desired height. The reading on the scale will indicate the string tension.
3. Can the string tension of a yo-yo be adjusted?
Yes, the string tension of a yo-yo can be adjusted by either changing the length of the string or by twisting the string. Increasing the length of the string will decrease the tension, while decreasing the length will increase the tension.
4. How does string tension affect the acceleration of a yo-yo?
The string tension of a yo-yo affects its acceleration by providing the force needed to move the yo-yo along the string. Higher string tension will result in a faster acceleration, while lower string tension will result in a slower acceleration.
5. Is there a relationship between string tension and the weight of a yo-yo?
Yes, there is a direct relationship between string tension and the weight of a yo-yo. A heavier yo-yo will require more force to move along the string, resulting in a higher string tension. On the other hand, a lighter yo-yo will require less force and result in a lower string tension.
